[GRASS-SVN] r74480 - in grass/trunk: gui/wxpython/core lib/python/script lib/python/script/testsuite
svn_grass at osgeo.org
Wed May 15 09:56:34 PDT 2019
Author: annakrat
Date: 2019-05-15 09:56:34 -0700 (Wed, 15 May 2019)
New Revision: 74480
grass/trunk/gui/wxpython/core/gcmd.py
grass/trunk/lib/python/script/core.py
grass/trunk/lib/python/script/testsuite/test_core_make_val.py
pythonlib: cleanup decoding/encoding in scripting library
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2019-05-14 20:18:15 UTC (rev 74479)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2019-05-15 16:56:34 UTC (rev 74480)
@@ -693,8 +693,8 @@
:return: returncode, stdout, messages (read == True and getErrorMsg == True)
:return: stdout, stderr
- cmdString = b' '.join(grass.make_command(prog, flags, overwrite,
- quiet, verbose, **kwargs))
+ cmdString = ' '.join(grass.make_command(prog, flags, overwrite,
+ quiet, verbose, **kwargs))
Debug.msg(1, "gcmd.RunCommand(): %s" % cmdString)
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2019-05-14 20:18:15 UTC (rev 74479)
+++ grass/trunk/lib/python/script/core.py 2019-05-15 16:56:34 UTC (rev 74480)
@@ -60,7 +60,6 @@
if ext.lower() not in self._builtin_exts:
kwargs['shell'] = True
args = [self._escape_for_shell(arg) for arg in args]
- args = [decode(arg) for arg in args]
subprocess.Popen.__init__(self, args, **kwargs)
PIPE = subprocess.PIPE
@@ -82,18 +81,16 @@
def _make_val(val):
- """Convert value to bytes"""
- if isinstance(val, bytes):
- return val
- if isinstance(val, (str, unicode)):
- return encode(val)
+ """Convert value to unicode"""
+ if isinstance(val, (bytes, str, unicode)):
+ return decode(val)
if isinstance(val, (int, float)):
- return encode(str(val))
+ return unicode(val)
try:
- return b",".join(map(_make_val, iter(val)))
+ return ",".join(map(_make_val, iter(val)))
except TypeError:
pass
- return bytes(val)
def _make_unicode(val, enc):
@@ -198,11 +195,11 @@
path.insert(0, os.curdir)
# PATHEXT is necessary to check on Windows (force lowercase)
- pathext = list(map(lambda x: encode(x.lower()),
+ pathext = list(map(lambda x: x.lower(),
os.environ.get("PATHEXT", "").split(os.pathsep)))
- if b'.py' not in pathext:
+ if '.py' not in pathext:
# we assume that PATHEXT contains always '.py'
- pathext.insert(0, b'.py')
+ pathext.insert(0, '.py')
# See if the given file matches any of the expected path extensions.
# This will allow us to short circuit when given "python.exe".
# If it does match, only test that one, otherwise we have to try
@@ -222,7 +219,7 @@
if not normdir in seen:
seen.add(normdir)
for thefile in files:
- name = os.path.join(encode(dir), thefile)
+ name = os.path.join(dir, thefile)
if _access_check(name, mode):
return name
return None
@@ -264,7 +261,7 @@
# so, lets remove extension
if os.path.splitext(cmd)[1] == '.py':
cmd = cmd[:-3]
- full_path = shutil_which(encode(cmd) + b'.py')
+ full_path = shutil_which(cmd + '.py')
if full_path:
return full_path
@@ -271,7 +268,7 @@
return cmd
-def make_command(prog, flags=b"", overwrite=False, quiet=False, verbose=False,
+def make_command(prog, flags="", overwrite=False, quiet=False, verbose=False,
superquiet=False, errors=None, **options):
"""Return a list of strings suitable for use as the args parameter to
Popen() or call(). Example:
@@ -292,26 +289,24 @@
args = [_make_val(prog)]
if overwrite:
- args.append(b"--o")
+ args.append("--o")
if quiet:
- args.append(b"--q")
+ args.append("--q")
if verbose:
- args.append(b"--v")
+ args.append("--v")
if superquiet:
- args.append(b"--qq")
+ args.append("--qq")
if flags:
flags = _make_val(flags)
- if b'-' in flags:
+ if '-' in flags:
raise ScriptError("'-' is not a valid flag")
- args.append(b"-" + bytes(flags))
+ args.append("-" + flags)
for opt, val in options.items():
if opt in _popen_args:
continue
# convert string to bytes
- opt = encode(opt)
- prog = encode(prog)
if val is not None:
- if opt.startswith(b'_'):
+ if opt.startswith('_'):
opt = opt[1:]
warning(_("To run the module <%s> add underscore at the end"
" of the option <%s> to avoid conflict with Python"
@@ -318,9 +313,9 @@
" keywords. Underscore at the beginning is"
" depreciated in GRASS GIS 7.0 and will be removed"
" in version 7.1.") % (prog, opt))
- elif opt.endswith(b'_'):
+ elif opt.endswith('_'):
opt = opt[:-1]
- args.append(opt + b'=' + _make_val(val))
+ args.append(opt + '=' + _make_val(val))
return args
@@ -337,11 +332,11 @@
else:
# TODO: construction of the whole command is far from perfect
args = make_command(*args, **kwargs)
- code = ' '.join([decode(each) for each in args])
+ code = ' '.join(args)
raise CalledModuleError(module=None, code=code,
returncode=returncode)
-def start_command(prog, flags=b"", overwrite=False, quiet=False,
+def start_command(prog, flags="", overwrite=False, quiet=False,
verbose=False, superquiet=False, **kwargs):
"""Returns a Popen object with the command created by make_command.
Accepts any of the arguments which Popen() accepts apart from "args"
@@ -379,8 +374,6 @@
popts[opt] = val
else:
- if isinstance(val, unicode):
- val = encode(val)
options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
@@ -388,11 +381,12 @@
if debug_level() > 0:
sys.stderr.write("D1/{}: {}.start_command(): {}\n".format(
debug_level(), __name__,
- ' '.join([decode(arg) for arg in args]))
+ ' '.join(args))
sys.stderr.flush()
return Popen(args, **popts)
def run_command(*args, **kwargs):
"""Execute a module synchronously
Modified: grass/trunk/lib/python/script/testsuite/test_core_make_val.py
--- grass/trunk/lib/python/script/testsuite/test_core_make_val.py 2019-05-14 20:18:15 UTC (rev 74479)
+++ grass/trunk/lib/python/script/testsuite/test_core_make_val.py 2019-05-15 16:56:34 UTC (rev 74480)
@@ -7,23 +7,23 @@
class TestCoreMakeVal(TestCase):
- """Tests function `_make_val` that convert value to bytes."""
+ """Tests function `_make_val` that convert value to unicode."""
def test_bytes(self):
- self.assertEqual(b'text', _make_val(b'text'))
+ self.assertEqual(u'text', _make_val(b'text'))
def test_unicode(self):
- self.assertEqual(b'text', _make_val(u'text'))
+ self.assertEqual(u'text', _make_val(u'text'))
def test_int(self):
- self.assertEqual(b'123', _make_val(123))
+ self.assertEqual(u'123', _make_val(123))
def test_float(self):
- self.assertEqual(b'1.23', _make_val(1.23))
+ self.assertEqual(u'1.23', _make_val(1.23))
def test_iterable(self):
- test = b'text', u'text', 123, 1.23
- solution = b'text,text,123,1.23'
+ test = u'text', u'text', 123, 1.23
+ solution = u'text,text,123,1.23'
self.assertEqual(solution, _make_val(test))
