[GRASS-SVN] r74483 - grass/trunk/imagery/i.vi/testsuite
Wed May 15 14:01:46 PDT 2019
Author: annakrat
Date: 2019-05-15 14:01:46 -0700 (Wed, 15 May 2019)
New Revision: 74483
   grass/trunk/imagery/i.vi/testsuite/test_vi.py
i.vi: fix testsuite
Modified: grass/trunk/imagery/i.vi/testsuite/test_vi.py
--- grass/trunk/imagery/i.vi/testsuite/test_vi.py	2019-05-15 20:56:35 UTC (rev 74482)
+++ grass/trunk/imagery/i.vi/testsuite/test_vi.py	2019-05-15 21:01:46 UTC (rev 74483)
@@ -1,7 +1,7 @@
 Purpose:    Tests i.vi and its flags/options.
 Author:     Sunveer Singh, Google Code-in 2017
 Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
 Licence:    This program is free software under the GNU General Public
@@ -10,12 +10,13 @@
 from grass.gunittest.case import TestCase
 class TestReport(TestCase):
-    blue='lsat5_1987_10'
-    green='lsat5_1987_20'
-    red='lsat5_1987_30'
-    nir= 'lsat5_1987_40'
+    blue = 'lsat5_1987_10'
+    green = 'lsat5_1987_20'
+    red = 'lsat5_1987_30'
+    nir = 'lsat5_1987_40'
     @classmethod
     def setUpClass(cls):
         """Use temporary region settings"""
@@ -32,12 +33,11 @@
         cls.runModule("g.remove", flags='f', type="raster", name="gari")
         cls.runModule("g.remove", flags='f', type="raster", name="gemi")
         cls.del_temp_region()
     def test_vinameipvi(self):
         """Testing viname ipvi"""
         map_output = 'ipvi'
-        self.assertModule('i.vi', red=self.red, nir=self.nir,
+        self.assertModule('i.vi', red=self.red, nir=self.nir,
                           output=map_output, viname='ipvi')
         self.assertRasterMinMax(map=map_output, refmin=0.0454545454545,
                                 refmax=0.906666666667,
@@ -58,7 +58,6 @@
                           output=map_output, viname='sr')
         self.assertRasterMinMax(map=map_output, refmin=0.04, refmax=9.73,
                                 msg="sr in percent must be between 0.04 and 9.72")
     def test_vinameevi(self):
         """Testing viname evi"""
@@ -77,13 +76,13 @@
         self.assertRasterMinMax(map=map_output, refmin=-0.33, refmax=0.74,
                                 msg="evi2 in degrees must be between -0.33 and 0.74")
-    def test_vinamegari(self):
+    def test_vinamegari(self):
         """Testing viname gari"""
         map_output = 'gari'
         self.assertModule('i.vi', red=self.red, nir=self.nir, blue=self.blue,
                           green=self.green, output=map_output, viname='gari')
         self.assertRasterMinMax(map=map_output, refmin=-1.58244128083e+17,
-                                refmax='inf',
+                                refmax=float('inf'),
                                 msg="gari in degrees must be between -1.58")
     def test_vinamegemi(self):
@@ -96,4 +95,4 @@
 if __name__ == '__main__':
     from grass.gunittest.main import test
-    test()
+    test()
