[GRASS-SVN] r74487 - grass/trunk/raster/r.slope.aspect/testsuite
svn_grass at osgeo.org
Wed May 15 20:28:37 PDT 2019
Author: annakrat
Date: 2019-05-15 20:28:36 -0700 (Wed, 15 May 2019)
New Revision: 74487
grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
r.slope.aspect: remove tmp outputs in test to be able to rerun it, add missing g.region call
Modified: grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
--- grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py 2019-05-15 21:43:03 UTC (rev 74486)
+++ grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py 2019-05-16 03:28:36 UTC (rev 74487)
@@ -19,25 +19,33 @@
class TestSlopeAspect(TestCase):
+ slope = 'limits_slope'
+ aspect = 'limits_aspect'
+ def setUp(self):
+ self.use_temp_region()
+ call_module('g.region', raster='elevation')
+ def tearDown(self):
+ self.del_temp_region()
+ call_module('g.remove', flags='f', type_='raster',
+ name=[self.slope, self.aspect])
def test_limits(self):
- slope = 'limits_slope'
- aspect = 'limits_aspect'
self.assertModule('r.slope.aspect', elevation='elevation',
- slope=slope, aspect=aspect)
- self.assertRasterMinMax(map=slope, refmin=0, refmax=90,
+ slope=self.slope, aspect=self.aspect)
+ self.assertRasterMinMax(map=self.slope, refmin=0, refmax=90,
msg="Slope in degrees must be between 0 and 90")
- self.assertRasterMinMax(map=aspect, refmin=0, refmax=360,
+ self.assertRasterMinMax(map=self.aspect, refmin=0, refmax=360,
msg="Aspect in degrees must be between 0 and 360")
def test_limits_precent(self):
"""Assumes NC elevation and allows slope up to 100% (45deg)"""
- slope = 'limits_percent_slope'
- aspect = 'limits_percent_aspect'
- slope=slope, aspect=aspect, format='percent')
- self.assertRasterMinMax(map=slope, refmin=0, refmax=100,
+ slope=self.slope, aspect=self.aspect, format='percent')
+ self.assertRasterMinMax(map=self.slope, refmin=0, refmax=100,
msg="Slope in percent must be between 0 and 100")
@@ -58,6 +66,10 @@
# precision for comparisons
precision = 0.0001
+ ref_aspect = 'reference_aspect'
+ aspect = 'fractal_aspect'
+ ref_slope = 'reference_slope'
+ slope = 'fractal_slope'
@classmethod
def setUpClass(cls):
@@ -65,42 +77,38 @@
call_module('g.region', n=20, s=10, e=25, w=15, res=1)
cls.elevation = 'fractal_surf'
cls.runModule('r.in.ascii', input='data/fractal_surf.ascii',
- output=cls.elevation)
+ output=cls.elevation)
@classmethod
def tearDownClass(cls):
cls.del_temp_region()
- cls.runModule('g.remove', flags='f', type='raster', name=cls.elevation)
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=[cls.elevation, cls.slope, cls.aspect, cls.ref_aspect, cls.ref_slope])
def test_slope(self):
- ref_slope = 'reference_slope'
- slope = 'fractal_slope'
# TODO: using gdal instead of ascii because of cannot seek error
self.runModule('r.in.gdal', flags='o',
- input='data/gdal_slope.grd', output=ref_slope)
+ input='data/gdal_slope.grd', output=self.ref_slope)
self.assertModule('r.slope.aspect', elevation=self.elevation,
- slope=slope)
+ slope=self.slope)
# check we have expected values
# check against reference data
- self.assertRastersNoDifference(actual=slope, reference=ref_slope,
+ self.assertRastersNoDifference(actual=self.slope, reference=self.ref_slope,
precision=self.precision)
def test_aspect(self):
- ref_aspect = 'reference_aspect'
- aspect = 'fractal_aspect'
- input='data/gdal_aspect.grd', output=ref_aspect)
+ input='data/gdal_aspect.grd', output=self.ref_aspect)
- aspect=aspect)
+ aspect=self.aspect)
- self.assertRastersNoDifference(actual=aspect, reference=ref_aspect,
+ self.assertRastersNoDifference(actual=self.aspect, reference=self.ref_aspect,
@@ -107,6 +115,11 @@
class TestSlopeAspectAgainstItself(TestCase):
precision = 0.0000001
+ elevation = 'elevation'
+ t_aspect = 'sa_together_aspect'
+ t_slope = 'sa_together_slope'
+ s_aspect = 'sa_separately_aspect'
+ s_slope = 'sa_separately_slope'
@classmethod
@@ -116,24 +129,21 @@
@classmethod
+ name=[cls.t_aspect, cls.t_slope, cls.s_slope, cls.s_aspect])
def test_slope_aspect_together(self):
"""Slope and aspect computed separately and together should be the same
- elevation = 'elevation'
- t_aspect = 'sa_together_aspect'
- t_slope = 'sa_together_slope'
- s_aspect = 'sa_separately_aspect'
- s_slope = 'sa_separately_slope'
- self.assertModule('r.slope.aspect', elevation=elevation,
- aspect=s_aspect)
- slope=s_slope)
- slope=t_slope, aspect=t_aspect)
- self.assertRastersNoDifference(actual=t_aspect, reference=s_aspect,
+ self.assertModule('r.slope.aspect', elevation=self.elevation,
+ aspect=self.s_aspect)
+ slope=self.s_slope)
+ slope=self.t_slope, aspect=self.t_aspect)
+ self.assertRastersNoDifference(actual=self.t_aspect, reference=self.s_aspect,
- self.assertRastersNoDifference(actual=t_slope, reference=s_slope,
+ self.assertRastersNoDifference(actual=self.t_slope, reference=self.s_slope,
@@ -140,24 +150,27 @@
# TODO: implement this class
class TestExtremes(TestCase):
+ slope = 'small_slope'
+ aspect = 'small_aspect'
+ elevation = 'small_elevation'
def setUp(self):
def tearDown(self):
+ name=[self.slope, self.aspect, self.elevation])
def test_small(self):
- elevation = 'small_elevation'
- slope = 'small_slope'
- aspect = 'small_aspect'
- self.runModule('r.in.ascii', input='-', output=elevation,
+ self.runModule('r.in.ascii', input='-', output=self.elevation,
stdin_=SMALL_MAP)
- call_module('g.region', raster=elevation)
+ call_module('g.region', raster=self.elevation)
