[GRASS-SVN] r74495 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Thu May 16 08:32:59 PDT 2019
Author: annakrat
Date: 2019-05-16 08:32:59 -0700 (Thu, 16 May 2019)
New Revision: 74495
grass/trunk/lib/python/gunittest/case.py
gunittest: cleanup, no decoding should be needed
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2019-05-16 15:03:19 UTC (rev 74494)
+++ grass/trunk/lib/python/gunittest/case.py 2019-05-16 15:32:59 UTC (rev 74495)
@@ -20,7 +20,6 @@
from grass.pygrass.modules import Module
from grass.exceptions import CalledModuleError
from grass.script import shutil_which
-from grass.script.utils import decode
from .gmodules import call_module, SimpleModule
from .checkers import (check_text_ellipsis,
@@ -169,14 +168,6 @@
If you need to test the actual newline characters, use the standard
string comparison and functions such as ``find()``.
- # SimpleModule delivers bytes for stderr and stdout
- # Instead of decoding stdout and stderr in every test, decoding
- # is done here
- if pyversion >= 3:
- if isinstance(first, bytes):
- first = decode(first)
- if isinstance(second, bytes):
- second = decode(second)
if os.linesep != '\n':
if os.linesep in first:
first = first.replace(os.linesep, '\n')
@@ -193,15 +184,9 @@
See :func:`check_text_ellipsis` for details of behavior.
- # is done here
- if isinstance(actual, bytes):
- actual = decode(actual)
- self.assertTrue(isinstance(actual, str), (
+ self.assertTrue(isinstance(actual, (str, unicode)), (
'actual argument is not a string'))
- self.assertTrue(isinstance(reference, str), (
+ self.assertTrue(isinstance(reference, (str, unicode)), (
'reference argument is not a string'))
if os.linesep != '\n' and os.linesep in actual:
actual = actual.replace(os.linesep, '\n')
@@ -240,7 +225,7 @@
reference = text_to_keyvalue(reference, sep=sep, skip_empty=True)
module = _module_from_parameters(module, **parameters)
self.runModule(module, expecting_stdout=True)
- raster_univar = text_to_keyvalue(decode(module.outputs.stdout),
+ raster_univar = text_to_keyvalue(module.outputs.stdout,
if not keyvalue_equals(dict_a=reference, dict_b=raster_univar,
a_is_subset=True, precision=precision):
@@ -418,18 +403,12 @@
This function does not test geometry itself just the region of the
vector map and number of features.
- # is done here
module = SimpleModule('v.info', flags='t', map=reference)
self.runModule(module)
- ref_topo = text_to_keyvalue(decode(module.outputs.stdout), sep='=')
+ ref_topo = text_to_keyvalue(module.outputs.stdout, sep='=')
module = SimpleModule('v.info', flags='g', map=reference)
- ref_info = text_to_keyvalue(decode(module.outputs.stdout), sep='=')
+ ref_info = text_to_keyvalue(module.outputs.stdout, sep='=')
self.assertVectorFitsTopoInfo(vector=actual, reference=ref_topo,
msg=msg)
self.assertVectorFitsRegionInfo(vector=actual, reference=ref_info,
@@ -481,7 +460,6 @@
`assertRasterFitsUnivar()` or `assertRasterFitsInfo()`
stdout = call_module('r.info', map=map, flags='r')
- stdout = decode(stdout)
actual = text_to_keyvalue(stdout, sep='=')
if refmin > actual['min']:
stdmsg = ('The actual minimum ({a}) is smaller than the reference'
@@ -512,7 +490,6 @@
`assertRaster3DFitsUnivar()` or `assertRaster3DFitsInfo()`
stdout = call_module('r3.info', map=map, flags='r')
@@ -898,13 +875,13 @@
# be more appropriate
self.assertVectorFitsTopoInfo(vector=intersection,
reference=ref_topo,
msg=msg)
self.assertVectorFitsRegionInfo(vector=intersection,
reference=ref_info,
msg=msg, precision=precision)
@@ -934,7 +911,7 @@
# 43=98606087.5818323
# 44=727592.902311112
# total area=2219442027.22035
- total_area = decode(module.outputs.stdout).splitlines()[-1].split('=')[-1]
+ total_area = module.outputs.stdout.splitlines()[-1].split('=')[-1]
if total_area > precision:
stdmsg = ("Area of difference of vectors <{va}> and <{vr}>"
" should be 0"
@@ -1105,7 +1082,7 @@
# here exception raised by run() with finish_=True would be
# almost enough but we want some additional info to be included
# in the test report
- errors = decode(module.outputs.stderr)
+ errors = module.outputs.stderr
# provide diagnostic at least in English locale
# TODO: standardized error code would be handy here
import re
@@ -1120,7 +1097,7 @@
module.get_python(),
errors=errors)
# TODO: use this also in assert and apply when appropriate
- if expecting_stdout and not decode(module.outputs.stdout).strip():
+ if expecting_stdout and not module.outputs.stdout.strip():
if module.outputs.stderr:
errors = " The errors are:\n" + module.outputs.stderr
@@ -1172,8 +1149,8 @@
module.run()
self.grass_modules.append(module.name)
except CalledModuleError:
- print(decode(module.outputs.stdout))
- print(decode(module.outputs.stderr))
+ print(module.outputs.stdout)
+ print(module.outputs.stderr)
# TODO: message format
# TODO: stderr?
stdmsg = ('Running <{m.name}> module ended'
@@ -1182,11 +1159,11 @@
'See the following errors:\n'
'{errors}'.format(
m=module, code=module.get_python(),
- errors=decode(module.outputs.stderr)
+ errors=module.outputs.stderr
self.fail(self._formatMessage(msg, stdmsg))
# log these to final report
# TODO: always or only if the calling test method failed?
# in any case, this must be done before self.fail()
@@ -1206,11 +1183,11 @@
module.run()
else:
stdmsg = ('Running <%s> ended with zero (successful) return code'
' when expecting module to fail' % module.get_python())
