[GRASS-SVN] r74505 - in grass/trunk/lib/python/pygrass: raster vector
svn_grass at osgeo.org
Thu May 16 14:11:05 PDT 2019
Author: annakrat
Date: 2019-05-16 14:11:05 -0700 (Thu, 16 May 2019)
New Revision: 74505
grass/trunk/lib/python/pygrass/raster/segment.py
grass/trunk/lib/python/pygrass/vector/abstract.py
pygrass: fixes for Python 3
Modified: grass/trunk/lib/python/pygrass/raster/segment.py
--- grass/trunk/lib/python/pygrass/raster/segment.py 2019-05-16 20:54:26 UTC (rev 74504)
+++ grass/trunk/lib/python/pygrass/raster/segment.py 2019-05-16 21:11:05 UTC (rev 74505)
@@ -27,8 +27,8 @@
def nseg(self):
rows = self.rows()
cols = self.cols()
- return ((rows + self.srows - 1) / self.srows) * \
- ((cols + self.scols - 1) / self.scols)
+ return int(((rows + self.srows - 1) / self.srows) *
+ ((cols + self.scols - 1) / self.scols))
def segments_in_mem(self):
if self.maxmem > 0 and self.maxmem < 100:
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2019-05-16 20:54:26 UTC (rev 74504)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2019-05-16 21:11:05 UTC (rev 74505)
@@ -127,7 +127,7 @@
def _get_organization(self):
"""Private method to obtain the Vector organization"""
- return libvect.Vect_get_organization(self.c_mapinfo)
+ return utils.decode(libvect.Vect_get_organization(self.c_mapinfo))
def _set_organization(self, org):
"""Private method to change the Vector organization"""
@@ -138,7 +138,7 @@
def _get_date(self):
"""Private method to obtain the Vector date"""
- return libvect.Vect_get_date(self.c_mapinfo)
+ return utils.decode(libvect.Vect_get_date(self.c_mapinfo))
def _set_date(self, date):
"""Private method to change the Vector date"""
@@ -149,7 +149,7 @@
def _get_person(self):
"""Private method to obtain the Vector person"""
- return libvect.Vect_get_person(self.c_mapinfo)
+ return utils.decode(libvect.Vect_get_person(self.c_mapinfo))
def _set_person(self, person):
"""Private method to change the Vector person"""
@@ -160,7 +160,7 @@
def _get_title(self):
"""Private method to obtain the Vector title"""
- return libvect.Vect_get_map_name(self.c_mapinfo)
+ return utils.decode(libvect.Vect_get_map_name(self.c_mapinfo))
def _set_title(self, title):
"""Private method to change the Vector title"""
@@ -171,7 +171,7 @@
def _get_map_date(self):
"""Private method to obtain the Vector map date"""
- date_str = libvect.Vect_get_map_date(self.c_mapinfo)
+ date_str = utils.decode(libvect.Vect_get_map_date(self.c_mapinfo))
try:
return datetime.datetime.strptime(date_str, self.date_fmt)
except:
@@ -198,7 +198,7 @@
def _get_comment(self):
"""Private method to obtain the Vector comment"""
- return libvect.Vect_get_comment(self.c_mapinfo)
+ return utils.decode(libvect.Vect_get_comment(self.c_mapinfo))
def _set_comment(self, comm):
"""Private method to set the Vector comment"""
