[GRASS-git] [OSGeo/grass] 02bff1: r.blend: Quote map names in r.mapcalc expressions....
Māris Nartišs noreply at github.com
Fri Mar 20 12:30:40 PDT 2020
  Branch: refs/heads/releasebranch_7_8
  Home:   https://github.com/OSGeo/grass
  Commit: 02bff13532a318516b5fb4fc4184aa22bdda1b3d
      https://github.com/OSGeo/grass/commit/02bff13532a318516b5fb4fc4184aa22bdda1b3d
  Author: Māris Nartišs <mn at sungis.lv>
  Date:   2020-03-20 (Fri, 20 Mar 2020)
  Changed paths:
    M scripts/r.blend/r.blend.py
    M scripts/r.grow/r.grow.py
    A scripts/r.grow/testsuite/test_r_grow_quoting.py
  Log Message:
  r.blend: Quote map names in r.mapcalc expressions. (#277)
* r.blend: Quote map names in r.mapcalc expressions.
Avoids failure if map / mapset name is also a valid mathematical expression.
* r.grow: Quote map names in mapcalc expression
* testsuite: r.grow test case for mapcalc map quoting.
Based on PR #347 and PR #277
Co-authored-by: Māris Nartišs <maris.nartiss at lu.lv>
