[GRASS-git] [OSGeo/grass] a92f41: wxGUI/g.gui.psmap: fix double click on the map fra...
Tomas Zigo
noreply at github.com
Sat Nov 21 19:03:01 PST 2020
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: a92f4115a82ec29053504190fb66eb625c85c984
https://github.com/OSGeo/grass/commit/a92f4115a82ec29053504190fb66eb625c85c984
Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
Date: 2020-11-21 (Sat, 21 Nov 2020)
Changed paths:
M gui/wxpython/psmap/dialogs.py
Log Message:
wxGUI/g.gui.psmap: fix double click on the map frame with vector map (#1055)
MapFramePanel class OnMap() event method is called twice if you click
on the added map frame rectangle. Once directly from construct method
and second time as registred select map widget event handler. When
events are triggered, one OnMap() method call get rasterTypeRadio widget
incorrect value (raster type) and than is called g.region command with
wrong raster map parameter (map type is vector).
res = grass.read_command("g.region", flags='gu', raster=map)
