[GRASS-git] [OSGeo/grass] 28bf45: doc: Refine the command line parsing doc for C (#1...
Denis Ovsienko
noreply at github.com
Fri Oct 16 19:29:48 PDT 2020
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: 28bf4590de3eb427618f9b220d6fbe4584f8ecf0
https://github.com/OSGeo/grass/commit/28bf4590de3eb427618f9b220d6fbe4584f8ecf0
Author: Denis Ovsienko <denis at ovsienko.info>
Date: 2020-10-16 (Fri, 16 Oct 2020)
Changed paths:
M lib/gis/gislib_cmdline_parsing.dox
Log Message:
doc: Refine the command line parsing doc for C (#1010)
Improve punctuation. Fix some grammar. Put which/that right. Reword some
sentences for clarity. Fix a few broken references. Lose some passive
voice. Relabel two sections to match the text. Wrap all structure member
names with <b>, wrap all inline C code fragments with <tt>. Amend the
example C code to get the whitespace around "set"/"not set" right in all
cases. Consistently use $ as the command line prompt in all CLI examples.
Use <th> for table header rows. Show answers[] elements as strings, not
integers.
