[GRASS-git] [OSGeo/grass] 902fb4: r.geomorphon: Translate a C comment into English (...
Denis Ovsienko noreply at github.com
Thu Oct 22 14:42:08 PDT 2020
  Branch: refs/heads/releasebranch_7_8
  Home:   https://github.com/OSGeo/grass
  Commit: 902fb4b78996ab3a00963bfd78378c2d58e5076e
      https://github.com/OSGeo/grass/commit/902fb4b78996ab3a00963bfd78378c2d58e5076e
  Author: Denis Ovsienko <denis at ovsienko.info>
  Date:   2020-10-22 (Thu, 22 Oct 2020)
  Changed paths:
    M raster/r.geomorphon/pattern.c
  Log Message:
  r.geomorphon: Translate a C comment into English (#972)
Use English for comments.
There is still need for review of the actual meaning, but probably just indicating a change from nadir to zenith or the other way around. Comment for the whole block with some more description would be preferred.
  Commit: 6ac3055acb1d22de6518b50fe18faf0b576d51d6
      https://github.com/OSGeo/grass/commit/6ac3055acb1d22de6518b50fe18faf0b576d51d6
  Changed paths:
    M locale/po/grassmods_ar.po
    M locale/po/grassmods_bn.po
    M locale/po/grassmods_cs.po
    M locale/po/grassmods_de.po
    M locale/po/grassmods_el.po
    M locale/po/grassmods_es.po
    M locale/po/grassmods_fi.po
    M locale/po/grassmods_fr.po
    M locale/po/grassmods_hu.po
    M locale/po/grassmods_id_ID.po
    M locale/po/grassmods_it.po
    M locale/po/grassmods_ja.po
    M locale/po/grassmods_ko.po
    M locale/po/grassmods_lv.po
    M locale/po/grassmods_ml.po
    M locale/po/grassmods_pl.po
    M locale/po/grassmods_pt.po
    M locale/po/grassmods_pt_BR.po
    M locale/po/grassmods_ro.po
    M locale/po/grassmods_ru.po
    M locale/po/grassmods_si.po
    M locale/po/grassmods_sl.po
    M locale/po/grassmods_ta.po
    M locale/po/grassmods_th.po
    M locale/po/grassmods_tr.po
    M locale/po/grassmods_uk.po
    M locale/po/grassmods_vi.po
    M locale/po/grassmods_zh.po
    M locale/po/grassmods_zh_CN.po
    M raster/r.geomorphon/main.c
    M raster/r.geomorphon/r.geomorphon.html
  Log Message:
  more proofreading for r.geomorphon (#991)
* r.geomorphon: Spell "search" correctly in main.c
* r.geomorphon: Fix some editorial issues in HTML doc
Fix names of the "forms" and "ternary" output parameters, spell "3**8"
instead of "38", translate a note into English, put bold markup right,
fix a number of typos, terminate some sentences with periods.
* r.geomorphon: Fix a typo in a comment. [skip ci]
Compare: https://github.com/OSGeo/grass/compare/f568b2ded59f...6ac3055acb1d
