[GRASS-git] [OSGeo/grass-addons] 2cb5f6: v.in.survey: module startup fix (#381)
Tomas Zigo
noreply at github.com
Wed Jan 13 21:01:21 PST 2021
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass-addons
Commit: 2cb5f62b8742c271ad9c8ee8e5ebb6dd599826df
https://github.com/OSGeo/grass-addons/commit/2cb5f62b8742c271ad9c8ee8e5ebb6dd599826df
Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
Date: 2021-01-14 (Thu, 14 Jan 2021)
Changed paths:
M grass7/vector/v.in.survey/v.in.survey.py
Log Message:
* fix order (MRO) for bases glob, files
* order (MRO) for bases glob, layer
* order (MRO) for bases glob, files
* order (MRO) for bases layer, Merge, dxf
* order (MRO) for bases glob, layer, Merge_init, Merge, dxf, dxf_layer_merged, dxf_layer
* make a 'done_lyrs' var a global var
* comment unused var
* fix 'final' local var
* set vector area map type 'v.centroid' command overwrite flag
* remove duplicate checking vector line map type name
* fix merge vector maps
