[GRASS-git] [OSGeo/grass] dc4097: r.geomorphon: remove multires-specific code (#1570)
    Denis Ovsienko
    noreply at github.com
    Sat Jun  5 08:35:45 PDT 2021
  Branch: refs/heads/master
  Home:   https://github.com/OSGeo/grass
  Commit: dc409701a931d096560de9d4a7a933697cca83c3
      https://github.com/OSGeo/grass/commit/dc409701a931d096560de9d4a7a933697cca83c3
  Author: Denis Ovsienko <denis at ovsienko.info>
  Date:   2021-06-05 (Sat, 05 Jun 2021)
  Changed paths:
    M locale/po/grassmods_ar.po
    M locale/po/grassmods_bn.po
    M locale/po/grassmods_cs.po
    M locale/po/grassmods_de.po
    M locale/po/grassmods_el.po
    M locale/po/grassmods_es.po
    M locale/po/grassmods_fi.po
    M locale/po/grassmods_fr.po
    M locale/po/grassmods_hu.po
    M locale/po/grassmods_id_ID.po
    M locale/po/grassmods_it.po
    M locale/po/grassmods_ja.po
    M locale/po/grassmods_ko.po
    M locale/po/grassmods_lv.po
    M locale/po/grassmods_ml.po
    M locale/po/grassmods_pl.po
    M locale/po/grassmods_pt.po
    M locale/po/grassmods_pt_BR.po
    M locale/po/grassmods_ro.po
    M locale/po/grassmods_ru.po
    M locale/po/grassmods_si.po
    M locale/po/grassmods_sl.po
    M locale/po/grassmods_ta.po
    M locale/po/grassmods_th.po
    M locale/po/grassmods_tr.po
    M locale/po/grassmods_uk.po
    M locale/po/grassmods_vi.po
    M locale/po/grassmods_zh.po
    M locale/po/grassmods_zh_CN.po
    M raster/r.geomorphon/local_proto.h
    M raster/r.geomorphon/main.c
    M raster/r.geomorphon/pattern.c
  Log Message:
The original code does not work: As the original developer explains, there
is no point in fixing it, because the intended use case can be
implemented with scripts around r.geomorphon instead of C code in it.
That said, leave multires.c be, it has been unused for a long time, but
the function in it might belong somewhere else.
This change addresses bug #1355.
