[GRASS-git] [OSGeo/grass] ae6e9c: wxGUI/vdigit: use 'FloatSpin' widget, which allows...
Tomas Zigo
noreply at github.com
Sat Oct 2 18:51:01 PDT 2021
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: ae6e9c46958c7a626aeb5201fcf3770f246a6790
https://github.com/OSGeo/grass/commit/ae6e9c46958c7a626aeb5201fcf3770f246a6790
Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
Date: 2021-10-03 (Sun, 03 Oct 2021)
Changed paths:
M gui/wxpython/vdigit/preferences.py
Log Message:
wxGUI/vdigit: use 'FloatSpin' widget, which allows you to set the decimal snapping threshold value (#1882)
* wxGUI/vdigit: use 'FloatSpin' widget, which allows you to set the decimal snapping threshold value
Allow setting decimal snapping treshold value (< 1.0) especially for LOCATION
with WGS84 coordinate system with degree map unit (1.0 degree is aproximatelly
111 km).
* Use 'FloatSpin' widget, which allows you to set the decimal query length value
