[GRASS-git] [OSGeo/grass] 702009: Use pkg-config for FreeType 2. (#1719)
Denis Ovsienko
noreply at github.com
Mon Sep 6 08:58:32 PDT 2021
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 7020091c85e307ecf77224a5e5b3129a45b0950a
https://github.com/OSGeo/grass/commit/7020091c85e307ecf77224a5e5b3129a45b0950a
Author: Denis Ovsienko <denis at ovsienko.info>
Date: 2021-09-06 (Mon, 06 Sep 2021)
Changed paths:
M configure
M configure.in
Log Message:
In package-based Linux distributions FreeType 2 headers tend to be in
/usr/include/freetype2; in particular, "pkg-config --cflags freetype2"
returns at least /usr/include/freetype2 in the list of directories on
Debian 10, Fedora 34, openSUSE 15.3 and Ubuntu 18.04/20.04. In the
FreeBSD port they are in /usr/local/include/freetype2 and in the NetBSD
pkgsrc package they are in /usr/pkg/include/freetype2. pkg-config is the
established means of managing this compexity for both the compiler and
the linker flags.
GRASS has been using both FreeType 2 and pkg-config, but not the two
together, and its default FreeType 2 include directory has been set to
/usr/include/freetype, which belongs to FreeType 1. This way, the
configure script always required the --with-freetype-includes=...
argument.
Fix the script to handle FreeType 2 the same way it handles Cairo: allow
to override the defaults if required, but default to the flags provided
by pkg-config so things usually just work:
$ ./configure
checking whether to use FreeType... yes
checking for location of FreeType includes...
checking for ft2build.h... yes
checking for location of FreeType library...
checking for FT_Init_FreeType in -lfreetype... yes
As a side effect, restore the stdlib.h/exit() declarations test block,
which was lost in commit f752840 (Ubuntu 20.04 autoreconf 2.13 does not
generate it, but openSUSE 15.3 autoreconf 2.13 does).
