[GRASS-git] [OSGeo/grass] 46cbb3: version: Reduce usage of the current version numbe...
Vaclav Petras
noreply at github.com
Sun Aug 28 04:18:43 PDT 2022
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 46cbb3803919aade8f2bb611c3daaaf7766659a6
https://github.com/OSGeo/grass/commit/46cbb3803919aade8f2bb611c3daaaf7766659a6
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2022-08-28 (Sun, 28 Aug 2022)
Changed paths:
M INSTALL
M mswindows/crosscompile.sh
M python/grass/gunittest/multirunner.py
M python/grass/script/setup.py
Log Message:
version: Reduce usage of the current version number (#2340)
When the current version is used, it needs to be updated usually every minor release. This reduces how much the current version is used where it is not essential.
* When in variable name, use more general variable name.
* When in comment or doc, use '<version>' or VV when no specific example is needed.
* When a specific version is need for an example, use 3.y.z which is obviously an example.
* When not essential in the context, remove it completely.
* Use build-time replacement for version on macOS.
* Use short variable name in Python example to keep the lines short.
