[GRASS-git] [OSGeo/grass-addons] 495803: r.in.nasadem: fix name 'srid' is not defined (#678)
Markus Neteler
noreply at github.com
Mon Jan 17 03:06:30 PST 2022
Branch: refs/heads/grass7
Home: https://github.com/OSGeo/grass-addons
Commit: 495803b20fd782b4c0a2f249221e34cb02b0ec1f
https://github.com/OSGeo/grass-addons/commit/495803b20fd782b4c0a2f249221e34cb02b0ec1f
Author: Markus Neteler <neteler at gmail.com>
Date: 2022-01-17 (Mon, 17 Jan 2022)
Changed paths:
M src/raster/r.in.nasadem/r.in.nasadem.py
Log Message:
* r.in.nasadem: fix name 'srid' is not defined
This PR fixes the following Python error:
GRASS eu_laea_epsg3035/nasadem:~ > r.in.nasadem user=xxxx password=yyyyy output=nasadem memory=4000 method=bilinear_f resolution=30
File "/home/mundialis/.grass8/addons/scripts/r.in.nasadem", line 645, in <module>
main()
File "/home/mundialis/.grass8/addons/scripts/r.in.nasadem", line 490, in main
SRCGISRC, TMPLOC = createTMPlocation()
File "/home/mundialis/.grass8/addons/scripts/r.in.nasadem", line 350, in createTMPlocation
currepsg = ":".join(srid.split(":")[-1:])
NameError: name 'srid' is not defined
ERROR: Region <r_in_nasadem_region_285028> not found
Error in atexit._run_exitfuncs:
File "/home/mundialis/.grass8/addons/scripts/r.in.nasadem", line 314, in cleanup
grass.run_command("g.region", region=tmpregionname)
File "/home/mundialis/software/grass80/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py", line 541, in run_command
return handle_errors(returncode, result=None, args=args, kwargs=kwargs)
File "/home/mundialis/software/grass80/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py", line 429, in handle_errors
raise CalledModuleError(module=module, code=code, returncode=returncode)
grass.exceptions.CalledModuleError: Module run `g.region region=r_in_nasadem_region_285028` ended with an error.
The subprocess ended with a non-zero return code: 1. See errors above the traceback or in the error output.
* simple remove of the offending superfluous line
