[GRASS-git] [OSGeo/grass] 120f19: v.db.univar: Add JSON output (#2386)
Vaclav Petras
noreply at github.com
Thu Jun 9 09:03:29 PDT 2022
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 120f198fca22a564334d7721fabbe8c6e299bf6b
https://github.com/OSGeo/grass/commit/120f198fca22a564334d7721fabbe8c6e299bf6b
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2022-06-09 (Thu, 09 Jun 2022)
Changed paths:
M scripts/db.univar/db.univar.py
M scripts/db.univar/testsuite/test_db_univar.py
A scripts/v.db.univar/tests/conftest.py
A scripts/v.db.univar/tests/v_db_univar_test.py
M scripts/v.db.univar/testsuite/test_v_db_univar.py
M scripts/v.db.univar/v.db.univar.html
M scripts/v.db.univar/v.db.univar.py
Log Message:
* Add JSON output to db.univar.
* Add JSON from db.univar to v.db.univar.
* All formats now handled through the format option.
* Output percentiles as two lists, not a mapping.
Tests:
* Old tests fixed.
* New tests are using pytest.
* Fixed values for test obtained from the plain output, so the new JSON output is checked to fit with the original.
* The tests with computation using NumPy would fail with different tests data, i.e., using n other than 10, fails the tests.
