[GRASS-git] [OSGeo/grass] 394970: CI: Compile r.example and v.example (#2351)
Vaclav Petras noreply at github.com
Sun May 1 11:37:40 PDT 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 394970d61c04570d7c8aaf6244cb4ed23d973a6a
      https://github.com/OSGeo/grass/commit/394970d61c04570d7c8aaf6244cb4ed23d973a6a
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2022-05-01 (Sun, 01 May 2022)
  Changed paths:
    M .github/workflows/pylint.yml
  Log Message:
Compiling the two example C modules was part of the release procedure. This makes it part of the CI.
For now the check is (strangely) in the Pylint workflow because it is documentation and that workflow already does a test build of Sphinx (all three need to build from source first). Other places would be a separate doc generating and checking workflow or adding these to GCC checks to ensure higher quality standard.
