[GRASS-git] [OSGeo/grass] 87901e: lib/imagery: fix missing SONAME (#2363)
Markus Neteler
noreply at github.com
Mon May 9 03:44:53 PDT 2022
Branch: refs/heads/releasebranch_8_0
Home: https://github.com/OSGeo/grass
Commit: 87901eecb9a7f74344b55b2407527856aff238fd
https://github.com/OSGeo/grass/commit/87901eecb9a7f74344b55b2407527856aff238fd
Author: Markus Neteler <neteler at gmail.com>
Date: 2022-05-09 (Mon, 09 May 2022)
Changed paths:
M lib/imagery/Makefile
Log Message:
The change implemented in #2269 actually didn't fix the SONAME problem (see issue #2268), at least on Fedora:
# status after PR 2269:
readelf -d /usr/lib64/grass80/lib/libgrass_imagery.so
Dynamic section at offset 0x16860 contains 31 entries:
Tag Type Name/Value
0x0000000000000001 (NEEDED) Shared library: [libgrass_gis.8.0.so]
0x0000000000000001 (NEEDED) Shared library: [libm.so.6]
0x0000000000000001 (NEEDED) Shared library: [libgrass_raster.8.0.so]
0x0000000000000001 (NEEDED) Shared library: [libgrass_vector.8.0.so]
0x0000000000000001 (NEEDED) Shared library: [libc.so.6]
0x000000000000001d (RUNPATH) Library runpath: [/usr/lib64/grass80/lib]
0x000000000000000c (INIT) 0x5000
0x000000000000000d (FINI) 0x11e8c
0x0000000000000019 (INIT_ARRAY) 0x17848
==> The SONAME is still missing which means that #2269 did not solve it (tested on Fedora).
With this PR (see e.g. also `lib/display/Makefile`) the SONAME appears:
readelf -d /home/mneteler/software/grass80/dist.x86_64-pc-linux-gnu/lib/libgrass_imagery.so
Dynamic section at offset 0x14db8 contains 30 entries:
Tag Type Name/Value
0x000000000000000e (SONAME) Library soname: [libgrass_imagery.8.0.so]
0x000000000000001d (RUNPATH) Library runpath: [/usr/local/grass80/lib]
0x000000000000000d (FINI) 0x10864
0x0000000000000019 (INIT_ARRAY) 0x15da0
which is a requirement to compile, install and run the GDAL-GRASS driver (https://github.com/OSGeo/gdal-grass).
