[GRASS-git] [OSGeo/grass] 20331e: Vlib: Return all intersection points from Vect_lin...
Māris Nartišs
noreply at github.com
Fri May 20 07:26:09 PDT 2022
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 20331ef5ee9f9b34ae692b42daa9d49006f4e28e
https://github.com/OSGeo/grass/commit/20331ef5ee9f9b34ae692b42daa9d49006f4e28e
Author: Māris Nartišs <maris.gis at gmail.com>
Date: 2022-05-20 (Fri, 20 May 2022)
Changed paths:
M lib/vector/Vlib/intersect.c
M lib/vector/Vlib/intersect2.c
A lib/vector/Vlib/testsuite/test_vlib_intersect.py
M vector/v.profile/testsuite/test_v_profile.py
Log Message:
Vlib: Return all intersection points from Vect_line_get_intersections (#2358)
* Vlib: report all line intersections in Vect_line_get_intersections|2()
Current implementation of function Vect_line_get_intersections() reports
a single intersection even if lines cross multiple times
(a buggy implementation introduced by me in 2008 with
https://trac.osgeo.org/grass/changeset/34306)
Added tests should cover most of line intersection cases.
Also fixes bug #2344 (+ a test case)
Contains an update to documentation (from PR #2359 by metzm; fixes #2345)
