[GRASS-git] [OSGeo/grass] 01e8b9: contributing: Add separate section for OSGeo serve...
Vaclav Petras
noreply at github.com
Tue May 31 09:45:35 PDT 2022
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 01e8b966a08c5b68f88ebcad6b60fb17f04240aa
https://github.com/OSGeo/grass/commit/01e8b966a08c5b68f88ebcad6b60fb17f04240aa
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2022-05-31 (Tue, 31 May 2022)
Changed paths:
M doc/howto_release.md
Log Message:
contributing: Add separate section for OSGeo server uploads (#2405)
* Get the tag using Git assuming another person is doing the change, so variables need to be created and update version script gives a different status.
* Move changelog step to the server section because it is needed only for that and the file is needed on the computer.
* Move winGRASS steps into a separate section (copied as is).
* Fix syntax error in the tagging part of the doc.
