[GRASS-git] [OSGeo/grass-addons] 6e011f: v.db.pyupdate: Fix to use latest v.db.select forma...
Anna Petrasova noreply at github.com
Thu Oct 6 20:21:17 PDT 2022
  Branch: refs/heads/grass8
  Home:   https://github.com/OSGeo/grass-addons
  Commit: 6e011fbd8ff60c05720c607a5a3180a901388531
      https://github.com/OSGeo/grass-addons/commit/6e011fbd8ff60c05720c607a5a3180a901388531
  Author: Anna Petrasova <kratochanna at gmail.com>
  Date:   2022-10-06 (Thu, 06 Oct 2022)
  Changed paths:
    M src/vector/v.db.pyupdate/testsuite/test_v_db_pyupdate.py
    M src/vector/v.db.pyupdate/v.db.pyupdate.py
  Log Message:
  v.db.pyupdate: Fix to use latest v.db.select format=json option (#810)
At one point during development v.db.select used -j flag for json output, but it was changed to format=json before release. v.db.pyupdate was using the old syntax. Tests are also updated, so they should run now. The bug which required use of XXX for NULLs is fixed, so the workaround is no longer needed.
