[GRASS-git] [OSGeo/grass] cdd84c: Fix trailing whitespace, EOF and file formatting (...
Nicklas Larsson
noreply at github.com
Thu Jan 26 05:10:40 PST 2023
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: cdd84c130cea04b204479e2efdc75c742efc4843
https://github.com/OSGeo/grass/commit/cdd84c130cea04b204479e2efdc75c742efc4843
Author: Nicklas Larsson <n_larsson at yahoo.com>
Date: 2023-01-26 (Thu, 26 Jan 2023)
Changed paths:
M .pre-commit-config.yaml
M .travis/linux.before_install.sh
M .travis/linux.install.sh
M AUTHORS
M COPYING
M Makefile
M REQUIREMENTS.md
M TODO
M Vagrantfile
M aclocal.m4
M binaryInstall.src
M binder/postBuild
M db/Makefile
M db/databaseintro.html
M db/db.columns/Makefile
M db/db.columns/db.columns.html
M db/db.connect/Makefile
M db/db.connect/db.connect.html
M db/db.copy/Makefile
M db/db.copy/db.copy.html
M db/db.createdb/Makefile
M db/db.databases/Makefile
M db/db.databases/db.databases.html
M db/db.describe/Makefile
M db/db.describe/db.describe.html
M db/db.drivers/Makefile
M db/db.dropdb/Makefile
M db/db.execute/Makefile
M db/db.execute/db.execute.html
M db/db.select/Makefile
M db/db.select/db.select.html
M db/db.tables/Makefile
M db/db.tables/db.tables.html
M db/drivers/dbf/grass-dbf.html
M db/drivers/mysql/Makefile
M db/drivers/mysql/grass-mesql.html
M db/drivers/mysql/grass-mysql.html
M db/drivers/odbc/TODO
M db/drivers/odbc/grass-odbc.html
M db/drivers/ogr/README
M db/drivers/postgres/README
M db/drivers/postgres/grass-pg.html
M db/drivers/sqlite/Makefile
M db/drivers/sqlite/README
M demolocation/PERMANENT/vector/country_boundaries/head
M display/d.colorlist/d.colorlist.html
M display/d.colortable/d.colortable.html
M display/d.erase/Makefile
M display/d.font/d.font.html
M display/d.geodesic/d.geodesic.html
M display/d.graph/d.graph.html
M display/d.grid/d.grid.html
M display/d.his/d.his.html
M display/d.histogram/d.histogram.html
M display/d.labels/d.labels.html
M display/d.legend.vect/Makefile
M display/d.legend.vect/d.legend.vect.html
M display/d.legend/README
M display/d.legend/d.legend.html
M display/d.mon/d.mon.html
M display/d.path/d.path.html
M display/d.rast.num/d.rast.num.html
M display/d.rast/Makefile
M display/d.rhumbline/d.rhumbline.html
M display/d.text/d.text.html
M display/d.title/d.title.html
M display/d.vect.chart/d.vect.chart.html
M display/d.vect.thematic/d.vect.thematic.html
M display/d.vect.thematic/d_vect_thematic_leg.txt
M display/d.vect/d.vect.html
M display/d.where/d.where.html
M display/displaydrivers.html
M doc/README
M doc/debugging.txt
M doc/gui/wxpython/example/README
M doc/html_documentation.txt
M doc/parms_flags.txt
M doc/projectionintro.html
M doc/python/README
M doc/raster/r.example/COMMENTS
M doc/vector/TODO
M doc/vector/grass51atts.fig
M doc/vector/grass51concept.fig
M general/Makefile
M general/g.access/g.access.html
M general/g.copy/Makefile
M general/g.copy/g.copy.html
M general/g.dirseps/Makefile
M general/g.filename/g.filename.html
M general/g.findfile/g.findfile.html
M general/g.gisenv/Makefile
M general/g.gisenv/g.gisenv.html
M general/g.gui/g.gui.html
M general/g.mapset/g.mapset.html
M general/g.message/g.message.html
M general/g.mkfontcap/g.mkfontcap.html
M general/g.parser/g.parser.html
M general/g.parser/test.pl
M general/g.parser/test.sh
M general/g.ppmtopng/Makefile
M general/g.proj/g.proj.html
M general/g.region/Makefile
M general/g.region/g.region.html
M general/g.rename/Makefile
M general/g.rename/g.rename.html
M general/g.setproj/README
M general/g.setproj/g.setproj.html
M general/g.tempfile/g.tempfile.html
M general/g.version/g.version.html
M general/manage/Makefile
M general/manage/lister/README
M grasslib.dox
M gui/icons/grass.appdata.xml
M gui/icons/grass/LICENSE.TXT
M gui/wxpython/core/testsuite/data/test_toolboxes_user_toolboxes.xml
M gui/wxpython/docs/wxGUI.html
M gui/wxpython/docs/wxGUI.iscatt.html
M gui/wxpython/docs/wxGUI.modules.html
M gui/wxpython/docs/wxGUI.nviz.html
M gui/wxpython/docs/wxGUI.vnet.html
M gui/wxpython/docs/wxgui_sphinx/_templates/layout.html.template
M gui/wxpython/docs/wxgui_sphinx/src/index.rst
M gui/wxpython/docs/wxgui_sphinx/src/wxgui_libraries.rst
M gui/wxpython/docs/wxgui_sphinx/src/wxgui_tools.rst
M gui/wxpython/gcp/g.gui.gcp.html
M gui/wxpython/iclass/g.gui.iclass.html
M gui/wxpython/image2target/g.gui.image2target.html
M gui/wxpython/photo2image/g.gui.photo2image.html
M gui/wxpython/psmap/g.gui.psmap.html
M gui/wxpython/rlisetup/g.gui.rlisetup.html
M gui/wxpython/timeline/g.gui.timeline.html
M gui/wxpython/vdigit/g.gui.vdigit.html
M gui/wxpython/xml/grass-gxm.dtd
M gui/wxpython/xml/grass-gxw.dtd
M gui/wxpython/xml/main_menu.dtd
M gui/wxpython/xml/main_menu.xml
M gui/wxpython/xml/menudata.README
M gui/wxpython/xml/module_items.dtd
M gui/wxpython/xml/module_tree.xml
M gui/wxpython/xml/toolboxes.dtd
M gui/wxpython/xml/wxgui_items.dtd
M gui/xml/Makefile
M gui/xml/README
M gui/xml/grass-interface.dtd
M imagery/Makefile
M imagery/i.albedo/i.albedo.html
M imagery/i.atcorr/BUGS
M imagery/i.atcorr/Makefile
M imagery/i.atcorr/README
M imagery/i.atcorr/create_iwave.py
M imagery/i.atcorr/i.atcorr.html
M imagery/i.atcorr/sensors_csv/README
M imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv
M imagery/i.atcorr/test_suite/ETM4.res
M imagery/i.biomass/i.biomass.html
M imagery/i.cca/i.cca.html
M imagery/i.cluster/i.cluster.html
M imagery/i.cluster/i_cluster_landsat_clustering.fig
M imagery/i.eb.eta/i.eb.eta.html
M imagery/i.eb.evapfr/i.eb.evapfr.html
M imagery/i.eb.hsebal01/i.eb.hsebal01.html
M imagery/i.eb.netrad/i.eb.netrad.html
M imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
M imagery/i.emissivity/i.emissivity.html
M imagery/i.evapo.mh/i.evapo.mh.html
M imagery/i.evapo.pm/i.evapo.pm.html
M imagery/i.evapo.time/i.evapo.time.html
M imagery/i.fft/i.fft.html
M imagery/i.find/Makefile
M imagery/i.gensig/i.gensig.html
M imagery/i.gensigset/i.gensigset.html
M imagery/i.group/i.group.html
M imagery/i.his.rgb/i.his.rgb.html
M imagery/i.ifft/i.ifft.html
M imagery/i.landsat.acca/i.landsat.acca.html
M imagery/i.landsat.toar/i.landsat.toar.html
M imagery/i.maxlik/i.maxlik.html
M imagery/i.modis.qc/i.modis.qc.html
M imagery/i.ortho.photo/Makefile
M imagery/i.ortho.photo/README
M imagery/i.ortho.photo/alg_camera_position.txt
M imagery/i.ortho.photo/alg_photo_rectify.txt
M imagery/i.ortho.photo/i.ortho.camera/i.ortho.camera.html
M imagery/i.ortho.photo/i.ortho.init/Makefile
M imagery/i.ortho.photo/i.ortho.init/i.ortho.init.html
M imagery/i.ortho.photo/i.ortho.photo/i.ortho.photo.html
M imagery/i.ortho.photo/i.ortho.rectify/Makefile
M imagery/i.ortho.photo/i.ortho.rectify/README
M imagery/i.ortho.photo/i.ortho.rectify/i.ortho.rectify.html
M imagery/i.ortho.photo/i.ortho.transform/i.ortho.transform.html
M imagery/i.ortho.photo/lib/TODO
M imagery/i.pca/i.pca.html
M imagery/i.rectify/README
M imagery/i.rectify/i.rectify.html
M imagery/i.rgb.his/i.rgb.his.html
M imagery/i.segment/README
M imagery/i.segment/i.segment.html
M imagery/i.segment/outline
M imagery/i.segment/testsuite/test_isegment.py
M imagery/i.smap/Makefile
M imagery/i.smap/i.smap.html
M imagery/i.target/i.target.html
M imagery/i.topo.corr/Makefile
M imagery/i.topo.corr/i.topo.corr.html
M imagery/i.topo.corr/i_topo_corr_angles.fig
M imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
M imagery/i.vi/i.vi.html
M imagery/i.zc/i.zc.html
M imagery/imageryintro.html
M include/Make/Dir.make
M include/Make/Doxygen.make
M include/Make/Grass.make
M include/Make/Install.make
M include/Make/Other.make
M include/Make/Platform.make.in
M include/Make/Rules.make
M include/Make/Stlib.make
M include/Make/Vars.make
M lib/Makefile
M lib/arraystats/arraystatslib.dox
M lib/btree2/btree2.dox
M lib/cairodriver/Makefile
M lib/cairodriver/cairodriver.dox
M lib/cairodriver/cairodriver.html
M lib/cdhc/README
M lib/cdhc/cdhclib.dox
M lib/cdhc/doc/goodness.bib
M lib/cdhc/doc/goodness.tex
M lib/cluster/Makefile
M lib/datetime/README
M lib/db/README
M lib/db/dbmi_base/Makefile
M lib/db/dbmi_base/README
M lib/db/dbmi_client/Makefile
M lib/db/dbmi_driver/Makefile
M lib/db/dbmilib.dox
M lib/db/sqlp/README
M lib/db/sqlp/sql.html
M lib/db/sqlp/sqlp.l
M lib/db/sqlp/sqlp.y
M lib/db/sqlp/test/README
M lib/db/sqlp/test/test
M lib/db/stubs/Makefile
M lib/driver/Makefile
M lib/dspf/Makefile
M lib/dspf/README
M lib/external/Makefile
M lib/external/ccmath/C01-matrix
M lib/external/ccmath/ccmathlib.dox
M lib/fonts/Makefile
M lib/gis/README.TYPE
M lib/gis/colors/inferno
M lib/gis/colors/magma
M lib/gis/colors/plasma
M lib/gis/colors/population
M lib/gis/datum.table
M lib/gis/datumtransform.table
M lib/gis/ellipse.table
M lib/gis/ellipse.table.solar.system
M lib/gis/gislib.dox
M lib/gis/gislib_cmdline_parsing.dox
M lib/gis/new_des
M lib/gis/renamed_options
M lib/gmath/README
M lib/gmath/TODO
M lib/gpde/gpdelib.dox
M lib/htmldriver/README
M lib/htmldriver/htmldriver.html
M lib/imagery/imagerylib.dox
M lib/init/README
M lib/init/grass-xterm-mac
M lib/init/grass.html
M lib/init/html_browser_mac.sh
M lib/init/license.txt
M lib/init/variables.html
M lib/lidar/README
M lib/linkm/README
M lib/manage/Makefile
M lib/manage/element_list
M lib/ogsf/README
M lib/ogsf/TODO
M lib/ogsf/ogsflib.dox
M lib/pngdriver/pngdriver.html
M lib/proj/Makefile
M lib/proj/README.txt
M lib/proj/projlib.dox
M lib/psdriver/psdriver.html
M lib/raster/Makefile
M lib/raster/rasterlib.dox
M lib/raster3d/raster3dlib.dox
M lib/raster3d/test/Makefile
M lib/raster3d/test/test.raster3d.lib.html
M lib/rst/Makefile
M lib/rst/interp_float/print_tree
M lib/rst/rstlib.dox
M lib/segment/segmentlib.dox
M lib/symbol/README
M lib/symbol/symbol/basic/pushpin
M lib/symbol/symbol/demo/smrk
M lib/symbol/symbol/extra/4pt_star
M lib/symbol/symbol/extra/airport
M lib/symbol/symbol/extra/alpha_flag
M lib/symbol/symbol/extra/bridge
M lib/symbol/symbol/geology/circle_cross
M lib/symbol/symbol/legend/area
M lib/symbol/symbol/legend/area_curved
M lib/symbol/symbol/n_arrows/fancy_compass
M lib/temporal/Makefile
M lib/temporal/SQL/Makefile
M lib/temporal/SQL/map_tables_template.sql
M lib/temporal/SQL/postgresql_delete_trigger.sql
M lib/temporal/SQL/raster3d_metadata_table.sql
M lib/temporal/SQL/raster3d_views.sql
M lib/temporal/SQL/raster_metadata_table.sql
M lib/temporal/SQL/raster_views.sql
M lib/temporal/SQL/sqlite3_delete_trigger.sql
M lib/temporal/SQL/stds_map_register_table_template.sql
M lib/temporal/SQL/stds_tables_template.sql
M lib/temporal/SQL/str3ds_metadata_table.sql
M lib/temporal/SQL/str3ds_views.sql
M lib/temporal/SQL/strds_metadata_table.sql
M lib/temporal/SQL/strds_views.sql
M lib/temporal/SQL/stvds_metadata_table.sql
M lib/temporal/SQL/stvds_views.sql
M lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
M lib/temporal/SQL/update_str3ds_metadata_template.sql
M lib/temporal/SQL/update_strds_metadata_template.sql
M lib/temporal/SQL/update_stvds_metadata_template.sql
M lib/temporal/SQL/vector_metadata_table.sql
M lib/temporal/SQL/vector_views.sql
M lib/vector/Vlib/Makefile
M lib/vector/Vlib/README
M lib/vector/Vlib/write_pg.c
M lib/vector/dglib/BUGS
M lib/vector/dglib/COPYING
M lib/vector/dglib/README
M lib/vector/dglib/dglib.dox
M lib/vector/dglib/examples/README
M lib/vector/neta/Makefile
M lib/vector/neta/netalib.dox
M lib/vector/rtree/Makefile.alone
M lib/vector/rtree/docs/MAILS
M lib/vector/rtree/docs/README.grass
M lib/vector/rtree/docs/README.txt
M lib/vector/vectorascii.html
M lib/vector/vectorlib.dox
M lib/vector/vectorlib_ascii.dox
M lib/vector/vectorlib_faq.dox
M lib/vector/vectorlib_files.dox
M lib/vector/vectorlib_indices.dox
M lib/vector/vectorlib_lists.dox
M lib/vector/vectorlib_pg.dox
M lib/vector/vectorlib_tin.dox
M lib/vector/vectorlib_topology.dox
M lib/vector/vedit/veditlib.dox
M locale/README
M locale/po/README
M locale/templates/README
M macosx/Makefile
M macosx/app/English.lproj/MainMenu.nib/classes.nib
M macosx/app/GRASS.applescript
M macosx/app/Makefile
M macosx/app/PkgInfo
M macosx/app/build_html_user_index.sh
M macosx/app/main.m
M macosx/bundle.make
M macosx/pkg/resources/ReadMe.rtf
M man/parser_standard_options.js
M misc/Makefile
M misc/m.cogo/TODO
M misc/m.cogo/m.cogo.html
M misc/m.measure/m.measure.html
M misc/m.nviz.script/m.nviz.script.html
M misc/m.transform/m.transform.html
M mswindows/external/rbatch/clip2r.js
M mswindows/external/rbatch/el.js
M ps/Makefile
M ps/ps.map/README
M ps/ps.map/ps.map.html
M python/grass/docs/Makefile
M python/grass/docs/_static/pygrass.css
M python/grass/docs/_templates/layout.html.template
M python/grass/docs/_templates/oholosidebar.html
M python/grass/docs/src/gunittest_running_tests.rst
M python/grass/docs/src/gunittest_testing.rst
M python/grass/docs/src/index.rst
M python/grass/docs/src/pygrass_gis.rst
M python/grass/docs/src/pygrass_index.rst
M python/grass/docs/src/pygrass_modules.rst
M python/grass/docs/src/temporal_framework.rst
M python/grass/gunittest/testsuite/data/simple_vector_map_ascii_4p_2l_2c_3b_dp14.txt
M python/grass/gunittest/testsuite/data/simple_vector_map_ascii_4p_2l_2c_3b_dp14_diff_header.txt
M python/grass/gunittest/testsuite/data/simple_vector_map_ascii_4p_2l_2c_3b_dp14_modified.txt
M python/grass/imaging/README
M python/grass/pydispatch/PKG-INFO
M python/grass/pydispatch/license.txt
M python/grass/pygrass/gis/Makefile
M python/grass/pygrass/messages/Makefile
M python/grass/pygrass/modules/grid/Makefile
M python/grass/pygrass/raster/Makefile
M python/grass/pygrass/tests/Makefile
M python/libgrass_interface_generator/Makefile
M raster/Makefile
M raster/r.basins.fill/r.basins.fill.html
M raster/r.basins.fill/testsuite/testrbf.py
M raster/r.buffer/r.buffer.html
M raster/r.buildvrt/r.buildvrt.html
M raster/r.carve/Makefile
M raster/r.carve/README
M raster/r.carve/r.carve.html
M raster/r.category/r.category.html
M raster/r.circle/r.circle.html
M raster/r.clump/r.clump.html
M raster/r.coin/r.coin.html
M raster/r.colors/r.colors.html
M raster/r.colors/tests/example1
M raster/r.colors/tests/example3
M raster/r.compress/r.compress.html
M raster/r.contour/Makefile
M raster/r.contour/README
M raster/r.contour/r.contour.html
M raster/r.contour/testsuite/testrc.py
M raster/r.cost/r.cost.html
M raster/r.covar/r.covar.html
M raster/r.cross/r.cross.html
M raster/r.describe/r.describe.html
M raster/r.distance/r.distance.html
M raster/r.drain/README
M raster/r.drain/r.drain.html
M raster/r.external.out/r.external.out.html
M raster/r.external/r.external.html
M raster/r.external/testsuite/data/generate_data.sh
M raster/r.fill.dir/README
M raster/r.fill.dir/r.fill.dir.html
M raster/r.fill.stats/r.fill.stats.html
M raster/r.fill.stats/testsuite/data/input_ascii.txt
M raster/r.fill.stats/testsuite/data/output_mean.txt
M raster/r.fill.stats/testsuite/data/output_median.txt
M raster/r.fill.stats/testsuite/data/output_mode.txt
M raster/r.fill.stats/testsuite/data/output_wmean.txt
M raster/r.flow/Makefile
M raster/r.flow/r.flow.html
M raster/r.geomorphon/r.geomorphon.html
M raster/r.grow.distance/r.grow.distance.html
M raster/r.gwflow/r.gwflow.html
M raster/r.his/r.his.html
M raster/r.horizon/TODO
M raster/r.horizon/r.horizon.html
M raster/r.in.ascii/r.in.ascii.html
M raster/r.in.ascii/testsuite/data/input_ascii.txt
M raster/r.in.ascii/testsuite/test_r_in_ascii.py
M raster/r.in.bin/README
M raster/r.in.bin/r.in.bin.html
M raster/r.in.gdal/r.in.gdal.html
M raster/r.in.gdal/testsuite/data/elevation.prj
M raster/r.in.gdal/testsuite/data/generate_data.sh
M raster/r.in.gridatb/README
M raster/r.in.lidar/r.in.lidar.html
M raster/r.in.mat/r.in.mat.html
M raster/r.in.pdal/r.in.pdal.html
M raster/r.in.xyz/r.in.xyz.html
M raster/r.info/r.info.html
M raster/r.info/testsuite/test_r_info.py
M raster/r.lake/r.lake.html
M raster/r.latlong/r.latlong.html
M raster/r.li/Makefile
M raster/r.li/TODO
M raster/r.li/r.li.cwed/Makefile
M raster/r.li/r.li.cwed/r.li.cwed.html
M raster/r.li/r.li.daemon/r.li.daemon.html
M raster/r.li/r.li.dominance/Makefile
M raster/r.li/r.li.dominance/r.li.dominance.html
M raster/r.li/r.li.edgedensity/Makefile
M raster/r.li/r.li.edgedensity/r.li.edgedensity.html
M raster/r.li/r.li.html
M raster/r.li/r.li.mpa/Makefile
M raster/r.li/r.li.mps/Makefile
M raster/r.li/r.li.mps/r.li.mps.html
M raster/r.li/r.li.padcv/Makefile
M raster/r.li/r.li.padcv/r.li.padcv.html
M raster/r.li/r.li.padrange/r.li.padrange.html
M raster/r.li/r.li.padsd/Makefile
M raster/r.li/r.li.padsd/r.li.padsd.html
M raster/r.li/r.li.patchdensity/Makefile
M raster/r.li/r.li.patchdensity/r.li.patchdensity.html
M raster/r.li/r.li.patchnum/r.li.patchnum.html
M raster/r.li/r.li.renyi/r.li.renyi.html
M raster/r.li/r.li.richness/Makefile
M raster/r.li/r.li.shannon/Makefile
M raster/r.li/r.li.shannon/r.li.shannon.html
M raster/r.li/r.li.shape/Makefile
M raster/r.li/r.li.shape/r.li.shape.html
M raster/r.li/r.li.simpson/Makefile
M raster/r.li/r.li.simpson/r.li.simpson.html
M raster/r.li/r.li.testing_sp_mov.sh
M raster/r.mapcalc/mapcalc.l
M raster/r.mapcalc/mapcalc.y
M raster/r.mapcalc/r3.mapcalc.html
M raster/r.mapcalc/test_suite/README
M raster/r.mapcalc/testsuite/const_map_test.sh
M raster/r.mfilter/filter
M raster/r.mfilter/r.mfilter.html
M raster/r.mfilter/testsuite/test_r_mfilter.py
M raster/r.mode/r.mode.html
M raster/r.neighbors/r.neighbors.html
M raster/r.null/r.null.html
M raster/r.object.geometry/r.object.geometry.html
M raster/r.out.bin/README
M raster/r.out.bin/r.out.bin.html
M raster/r.out.gdal/r.out.gdal.html
M raster/r.out.gridatb/README
M raster/r.out.mat/r.out.mat.html
M raster/r.out.mpeg/README
M raster/r.out.mpeg/r.out.mpeg.html
M raster/r.out.pov/r.out.pov.html
M raster/r.out.ppm/r.out.ppm.html
M raster/r.out.vrml/r.out.vrml.html
M raster/r.out.vtk/r.out.vtk.html
M raster/r.param.scale/README
M raster/r.param.scale/cols.sh
M raster/r.param.scale/disp_matrix.c
M raster/r.patch/r.patch.html
M raster/r.path/r.path.html
M raster/r.profile/r.profile.html
M raster/r.proj/r.proj.html
M raster/r.quant/r.quant.html
M raster/r.quantile/r.quantile.html
M raster/r.random.cells/README
M raster/r.random.cells/r.random.cells.html
M raster/r.random.surface/r.random.surface.html
M raster/r.reclass/r.reclass.html
M raster/r.reclass/testsuite/test_r_reclass.py
M raster/r.recode/r.recode.html
M raster/r.regression.line/r.regression.line.html
M raster/r.relief/r.relief.html
M raster/r.resamp.bspline/Makefile
M raster/r.resamp.bspline/r.resamp.bspline.html
M raster/r.resamp.filter/r.resamp.filter.html
M raster/r.resamp.interp/r.resamp.interp.html
M raster/r.resamp.rst/BUGS
M raster/r.resamp.rst/DESCRIPTION
M raster/r.resamp.rst/HISTORY
M raster/r.resamp.rst/Makefile
M raster/r.resamp.rst/README
M raster/r.resamp.rst/r.resamp.rst.html
M raster/r.resample/r.resample.html
M raster/r.rescale.eq/r.rescale.eq.html
M raster/r.rescale/r.rescale.html
M raster/r.series.accumulate/r.series.accumulate.html
M raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh
M raster/r.series.interp/r.series.interp.html
M raster/r.series.interp/testsuite/data/outfile_1.txt
M raster/r.series/r.series.html
M raster/r.series/test_suite/test.r.series.sh
M raster/r.sim/Makefile
M raster/r.sim/r.sim.sediment/Makefile
M raster/r.sim/r.sim.sediment/r.sim.sediment.html
M raster/r.sim/r.sim.water/Makefile
M raster/r.sim/r.sim.water/r.sim.water.html
M raster/r.slope.aspect/r.slope.aspect.html
M raster/r.slope.aspect/testsuite/data/gdal_aspect.grd
M raster/r.slope.aspect/testsuite/data/gdal_slope.grd
M raster/r.solute.transport/r.solute.transport.html
M raster/r.spreadpath/r.spreadpath.html
M raster/r.statistics/gauss.dat
M raster/r.statistics/r.statistics.html
M raster/r.stats.quantile/r.stats.quantile.html
M raster/r.stats.zonal/r.stats.zonal.html
M raster/r.stats/r.stats.html
M raster/r.stream.extract/r.stream.extract.html
M raster/r.sun/README
M raster/r.sun/TODO
M raster/r.sun/r.sun.html
M raster/r.sunhours/r.sunhours.html
M raster/r.sunmask/README
M raster/r.sunmask/TODO
M raster/r.sunmask/r.sunmask.html
M raster/r.support.stats/r.support.stats.html
M raster/r.support/Makefile
M raster/r.support/r.support.html
M raster/r.surf.area/r.surf.area.html
M raster/r.surf.contour/r.surf.contour.html
M raster/r.surf.fractal/README
M raster/r.surf.fractal/r.surf.fractal.html
M raster/r.surf.gauss/README
M raster/r.surf.idw/r.surf.idw.html
M raster/r.surf.random/r.surf.random.html
M raster/r.terraflow/r.terraflow.html
M raster/r.texture/r.texture.html
M raster/r.texture/testsuite/test_texture.py
M raster/r.thin/r.thin.html
M raster/r.tile/r.tile.html
M raster/r.tile/testsuite/testrt.py
M raster/r.timestamp/r.timestamp.html
M raster/r.timestamp/test_suite/test.r.timestamp.sh
M raster/r.to.rast3/r.to.rast3.html
M raster/r.to.rast3/test_suite/test.r.to.rast3.sh
M raster/r.to.rast3elev/r.to.rast3elev.html
M raster/r.to.rast3elev/test.r.to.rast3elev.sh
M raster/r.to.vect/Makefile
M raster/r.to.vect/r.to.vect.html
M raster/r.topidx/README
M raster/r.transect/r.transect.html
M raster/r.univar/r.univar.html
M raster/r.uslek/r.uslek.html
M raster/r.viewshed/BUGS
M raster/r.viewshed/Makefile
M raster/r.viewshed/r.viewshed.html
M raster/r.volume/r.volume.html
M raster/r.walk/r.walk.html
M raster/r.watershed/Makefile
M raster/r.watershed/front/r.watershed.html
M raster/r.what/r.what.html
M raster/r.what/testsuite/testrw.py
M raster/rasterintro.html
M raster3d/Makefile
M raster3d/r3.cross.rast/test.r3.cross.rast.sh
M raster3d/r3.flow/Makefile
M raster3d/r3.flow/r3.flow.html
M raster3d/r3.gradient/r3.gradient.html
M raster3d/r3.gradient/testsuite/data/test_map_1
M raster3d/r3.gradient/testsuite/data/test_map_2
M raster3d/r3.gwflow/r3.gwflow.html
M raster3d/r3.in.ascii/r3.in.ascii.html
M raster3d/r3.in.bin/r3.in.bin.html
M raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh
M raster3d/r3.in.lidar/r3.in.lidar.html
M raster3d/r3.info/r3.info.html
M raster3d/r3.mask/r3.mask.html
M raster3d/r3.mkdspf/r3.mkdspf.html
M raster3d/r3.neighbors/r3.neighbors.html
M raster3d/r3.neighbors/test_suite/test.r3.neighbors.sh
M raster3d/r3.null/r3.null.html
M raster3d/r3.null/testsuite/test.r3.null.sh
M raster3d/r3.out.ascii/r3.out.ascii.html
M raster3d/r3.out.ascii/test.r3.out.ascii.sh
M raster3d/r3.out.netcdf/r3.out.netcdf.html
M raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
M raster3d/r3.out.v5d/BUG
M raster3d/r3.out.v5d/r3.out.v5d.html
M raster3d/r3.out.vtk/r3.out.vtk.html
M raster3d/r3.out.vtk/test.r3.out.vtk.sh
M raster3d/r3.retile/r3.retile.html
M raster3d/r3.retile/test.r3.retile.sh
M raster3d/r3.showdspf/README
M raster3d/r3.showdspf/TODO
M raster3d/r3.showdspf/r3.showdspf.html
M raster3d/r3.stats/r3.stats.html
M raster3d/r3.stats/test.r3.stats.sh
M raster3d/r3.support/Makefile
M raster3d/r3.support/r3.support.html
M raster3d/r3.timestamp/r3.timestamp.html
M raster3d/r3.timestamp/test_suite/test.r3.timestamp.sh
M raster3d/r3.to.rast/r3.to.rast.html
M raster3d/r3.to.rast/test.r3.to.rast.sh
M raster3d/raster3dintro.html
M renovate.json
M rpm/grass-pkgconfig.patch
M scripts/Makefile
M scripts/d.frame/d.frame.html
M scripts/d.out.file/d.out.file.html
M scripts/d.polar/d.polar.html
M scripts/d.rast.edit/d.rast.edit.html
M scripts/d.rast.leg/d.rast.leg.html
M scripts/d.redraw/d.redraw.html
M scripts/d.to.rast/d.to.rast.html
M scripts/d.what.rast/d.what.rast.html
M scripts/d.what.vect/d.what.vect.html
M scripts/db.in.ogr/db.in.ogr.html
M scripts/db.test/README
M scripts/db.test/db.test.html
M scripts/db.test/test1
M scripts/g.extension/g.extension.html
M scripts/i.band.library/landsat.json
M scripts/i.band.library/sentinel.json
M scripts/i.colors.enhance/i.colors.enhance.html
M scripts/i.in.spotvgt/i.in.spotvgt.html
M scripts/i.oif/i.oif.html
M scripts/i.pansharpen/i.pansharpen.html
M scripts/i.spectral/README
M scripts/i.tasscap/i.tasscap.html
M scripts/m.proj/m.proj.html
M scripts/r.buffer.lowmem/r.buffer.lowmem.html
M scripts/r.drain/Makefile
M scripts/r.drain/README
M scripts/r.drain/r.drain.html
M scripts/r.fillnulls/r.fillnulls.html
M scripts/r.grow/r.grow.html
M scripts/r.import/testsuite/data/data2.prj
M scripts/r.in.aster/r.in.aster.html
M scripts/r.in.srtm/r.in.srtm.html
M scripts/r.in.wms/r.in.wms.html
M scripts/r.mapcalc.simple/testsuite/test_rmapcalcsimple.py
M scripts/r.mask/r.mask.html
M scripts/r.out.xyz/r.out.xyz.html
M scripts/r.plane/r.plane.html
M scripts/r.reclass.area/r.reclass.area.html
M scripts/r.reclass.area/testsuite/testrra.py
M scripts/r.unpack/test_suite/test.r.unpack.sh
M scripts/v.centroids/v.centroids.html
M scripts/v.clip/v.clip.html
M scripts/v.db.addtable/v.db.addtable.html
M scripts/v.db.droprow/v.db.droprow.html
M scripts/v.db.droptable/v.db.droptable.html
M scripts/v.db.reconnect.all/v.db.reconnect.all.html
M scripts/v.db.renamecolumn/v.db.renamecolumn.html
M scripts/v.db.univar/v.db.univar.html
M scripts/v.import/v.import.html
M scripts/v.in.geonames/v.in.geonames.html
M scripts/v.in.mapgen/v.in.mapgen.html
M scripts/v.in.wfs/v.in.wfs.html
M scripts/v.report/v.report.html
M scripts/v.unpack/testsuite/test.v.unpack.sh
M scripts/v.what.vect/v.what.vect.html
M temporal/Makefile
M temporal/benchmark.sh
M temporal/run_all_tests.sh
M temporal/t.connect/Makefile
M temporal/t.copy/t.copy.html
M temporal/t.info/testsuite/test.t.info.sh
M temporal/t.list/t.list.html
M temporal/t.merge/t.merge.html
M temporal/t.merge/testsuite/test.t.merge.sh
M temporal/t.rast.accdetect/t.rast.accdetect.html
M temporal/t.rast.accumulate/t.rast.accumulate.html
M temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html
M temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh
M temporal/t.rast.algebra/t.rast.algebra.html
M temporal/t.rast.colors/test.t.rast.colors.sh
M temporal/t.rast.contour/t.rast.contour.html
M temporal/t.rast.export/test.t.rast.export.sh
M temporal/t.rast.gapfill/t.rast.gapfill.html
M temporal/t.rast.import/t.rast.import.html
M temporal/t.rast.import/test.t.rast.import.relative.sh
M temporal/t.rast.import/test.t.rast.import.sh
M temporal/t.rast.import/test.t.rast.import_locations.sh
M temporal/t.rast.list/testsuite/test_t_rast_list.sh
M temporal/t.rast.mapcalc/example.sh
M temporal/t.rast.mapcalc/t.rast.mapcalc.html
M temporal/t.rast.mapcalc/test.t.rast.mapcalc.operators.sh
M temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
M temporal/t.rast.neighbors/test.t.rast.neighbors.sh
M temporal/t.rast.out.vtk/t.rast.out.vtk.html
M temporal/t.rast.out.vtk/test.t.rast.out.vtk.sh
M temporal/t.rast.series/t.rast.series.html
M temporal/t.rast.series/test.t.rast.series.sh
M temporal/t.rast.series/test_t.sereis_bug_3223.sh
M temporal/t.rast.to.rast3/t.rast.to.rast3.html
M temporal/t.rast.to.vect/t.rast.to.vect.html
M temporal/t.rast.what/t.rast.what.html
M temporal/t.rast3d.algebra/t.rast3d.algebra.html
M temporal/t.rast3d.extract/t.rast3d.extract.html
M temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh
M temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html
M temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
M temporal/t.rast3d.univar/t.rast3d.univar.html
M temporal/t.register/t.register.html
M temporal/t.register/test.t.register.raster.file.sh
M temporal/t.register/test.t.register.vector.file.layer.sh
M temporal/t.register/test.t.register.vector.sh
M temporal/t.rename/test.t.rename.sh
M temporal/t.sample/t.sample.html
M temporal/t.sample/testsuite/test.t.sample.sh
M temporal/t.select/t.select.html
M temporal/t.shift/t.shift.html
M temporal/t.snap/test.t.snap.absolute.sh
M temporal/t.snap/test.t.snap.relative.sh
M temporal/t.support/test.t.support.sh
M temporal/t.topology/test.t.topology.abstime.sh
M temporal/t.topology/test.t.topology.reltime.sh
M temporal/t.vect.algebra/t.vect.algebra.html
M temporal/t.vect.db.select/test.t.vect.db.select.sh
M temporal/t.vect.export/test.t.vect.export.sh
M temporal/t.vect.extract/t.vect.extract.html
M temporal/t.vect.extract/test.t.vect.extract.layer.sh
M temporal/t.vect.extract/test.t.vect.extract.sh
M temporal/t.vect.import/t.vect.import.html
M temporal/t.vect.import/testsuite/test.t.vect.import.sh
M temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
M temporal/t.vect.list/testsuite/test.t.vect.list.sh
M temporal/t.vect.observe.strds/t.vect.observe.strds.html
M temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
M temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
M temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
M temporal/t.vect.univar/testsuite/test.t.vect.univar.sh
M temporal/t.vect.what.strds/t.vect.what.strds.html
M temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
M temporal/t.vect.what.strds/test.t.vect.what.strds.sh
M temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh
M testsuite/Makefile
M testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
M testsuite/raster/README
M testsuite/raster/rhemisphere.sh
M translators.csv
M utils/copywrite.pl
M utils/dep_tree2sql.sh
M utils/fix_typos.sh
M utils/grass_indent.sh
M utils/module_synopsis.sh
M utils/pep8config.txt
M utils/pylintrc.txt
M utils/symbol_to_img.sh
M vector/Makefile
M vector/v.buffer/v.buffer.html
M vector/v.build.polylines/Makefile
M vector/v.build.polylines/README
M vector/v.build.polylines/v.build.polylines.html
M vector/v.build/Makefile
M vector/v.category/Makefile
M vector/v.category/v.category.html
M vector/v.class/Makefile
M vector/v.class/v.class.html
M vector/v.clean/Makefile
M vector/v.clean/test/v.clean.test
M vector/v.clean/test/v.rand.poly
M vector/v.clean/v.clean.html
M vector/v.cluster/v.cluster.html
M vector/v.db.connect/Makefile
M vector/v.db.connect/v.db.connect.html
M vector/v.db.select/Makefile
M vector/v.delaunay/Makefile
M vector/v.delaunay/v.delaunay.html
M vector/v.distance/Makefile
M vector/v.distance/v.distance.html
M vector/v.drape/Makefile
M vector/v.drape/spearfish.pov
M vector/v.edit/v.edit.html
M vector/v.external.out/v.external.out.html
M vector/v.external/Makefile
M vector/v.external/v.external.html
M vector/v.extract/Makefile
M vector/v.extract/testsuite/test_v_extract.py
M vector/v.extract/v.extract.html
M vector/v.generalize/Makefile
M vector/v.generalize/v.generalize.html
M vector/v.hull/README
M vector/v.hull/v.hull.html
M vector/v.in.ascii/v.in.ascii.html
M vector/v.in.db/v.in.db.html
M vector/v.in.dwg/README
M vector/v.in.dwg/WARNING
M vector/v.in.dxf/Makefile
M vector/v.in.lidar/Makefile
M vector/v.in.lidar/v.in.lidar.html
M vector/v.in.ogr/Makefile
M vector/v.in.ogr/testsuite/data/precip_30ynormals_3d.prj
M vector/v.in.ogr/v.in.ogr.html
M vector/v.in.region/Makefile
M vector/v.in.region/v.in.region.html
M vector/v.info/v.info.html
M vector/v.kcv/v.kcv.html
M vector/v.kernel/Makefile
M vector/v.kernel/v.kernel.html
M vector/v.label/Makefile
M vector/v.label/v.label.html
M vector/v.lidar.correction/Makefile
M vector/v.lidar.correction/v.lidar.correction.html
M vector/v.lidar.edgedetection/Makefile
M vector/v.lidar.edgedetection/v.lidar.edgedetection.html
M vector/v.lidar.growing/Makefile
M vector/v.lidar.growing/v.lidar.growing.html
M vector/v.lrs/MAIL
M vector/v.lrs/Makefile
M vector/v.lrs/lib/Makefile
M vector/v.lrs/lrs.html
M vector/v.lrs/v.lrs.create/Makefile
M vector/v.lrs/v.lrs.create/v.lrs.create.html
M vector/v.lrs/v.lrs.label/Makefile
M vector/v.lrs/v.lrs.segment/Makefile
M vector/v.lrs/v.lrs.where/Makefile
M vector/v.mkgrid/v.mkgrid.html
M vector/v.neighbors/Makefile
M vector/v.neighbors/v.neighbors.html
M vector/v.net.alloc/Makefile
M vector/v.net.alloc/v.net.alloc.html
M vector/v.net.allpairs/Makefile
M vector/v.net.allpairs/v.net.allpairs.html
M vector/v.net.bridge/Makefile
M vector/v.net.bridge/v.net.bridge.html
M vector/v.net.centrality/Makefile
M vector/v.net.centrality/v.net.centrality.html
M vector/v.net.components/Makefile
M vector/v.net.components/v.net.components.html
M vector/v.net.connectivity/Makefile
M vector/v.net.connectivity/v.net.connectivity.html
M vector/v.net.distance/Makefile
M vector/v.net.distance/v.net.distance.html
M vector/v.net.flow/Makefile
M vector/v.net.flow/v.net.flow.html
M vector/v.net.iso/Makefile
M vector/v.net.iso/v.net.iso.html
M vector/v.net.path/Makefile
M vector/v.net.path/v.net.path.html
M vector/v.net.salesman/Makefile
M vector/v.net.salesman/v.net.salesman.html
M vector/v.net.spanningtree/Makefile
M vector/v.net.spanningtree/v.net.spanningtree.html
M vector/v.net.steiner/Makefile
M vector/v.net.steiner/v.net.steiner.html
M vector/v.net.timetable/Makefile
M vector/v.net.timetable/v.net.timetable.html
M vector/v.net.visibility/Makefile
M vector/v.net.visibility/v.net.visibility.html
M vector/v.net/Makefile
M vector/v.net/v.net.html
M vector/v.normal/v.normal.html
M vector/v.out.ascii/v.out.ascii.html
M vector/v.out.dxf/Makefile
M vector/v.out.lidar/Makefile
M vector/v.out.ogr/v.out.ogr.html
M vector/v.out.pov/Makefile
M vector/v.out.svg/v.out.svg.html
M vector/v.out.vtk/v.out.vtk.html
M vector/v.outlier/Makefile
M vector/v.overlay/Makefile
M vector/v.overlay/v.overlay.html
M vector/v.parallel/Makefile
M vector/v.patch/Makefile
M vector/v.patch/v.patch.html
M vector/v.perturb/v.perturb.html
M vector/v.perturb/zufall.c.README
M vector/v.perturb/zufall.f77.README
M vector/v.proj/Makefile
M vector/v.proj/v.proj.html
M vector/v.qcount/cressie.vm
M vector/v.qcount/v.qcount.html
M vector/v.random/test.v.random.sh
M vector/v.random/v.random.html
M vector/v.reclass/Makefile
M vector/v.reclass/v.reclass.html
M vector/v.rectify/v.rectify.html
M vector/v.sample/README
M vector/v.sample/v.sample.html
M vector/v.segment/Makefile
M vector/v.segment/v.segment.html
M vector/v.select/Makefile
M vector/v.select/v.select.html
M vector/v.split/Makefile
M vector/v.split/v.split.html
M vector/v.surf.bspline/Makefile
M vector/v.surf.bspline/test_suite/profile_cmd.sh
M vector/v.surf.bspline/v.surf.bspline.html
M vector/v.surf.idw/v.surf.idw.html
M vector/v.surf.rst/BUGS
M vector/v.surf.rst/DESCRIPTION
M vector/v.surf.rst/HISTORY
M vector/v.surf.rst/Makefile
M vector/v.surf.rst/README
M vector/v.surf.rst/test_suite/profile.sh
M vector/v.surf.rst/v.surf.rst.html
M vector/v.timestamp/test_suite/test.v.timestamp.sh
M vector/v.to.3d/Makefile
M vector/v.to.db/Makefile
M vector/v.to.db/v.to.db.html
M vector/v.to.points/Makefile
M vector/v.to.points/v.to.points.html
M vector/v.to.rast/Makefile
M vector/v.to.rast/v.to.rast.html
M vector/v.to.rast3/Makefile
M vector/v.to.rast3/test.v.to.rast3.sh
M vector/v.transform/Makefile
M vector/v.transform/v.transform.html
M vector/v.type/Makefile
M vector/v.univar/Makefile
M vector/v.univar/testsuite/v_univar_test.py
M vector/v.univar/v.univar.html
M vector/v.vect.stats/Makefile
M vector/v.vect.stats/testsuite/test_vect_stats.py
M vector/v.vect.stats/v.vect.stats.html
M vector/v.vol.rst/README
M vector/v.vol.rst/v.vol.rst.html
M vector/v.voronoi/README
M vector/v.voronoi/v.voronoi.html
M vector/v.what.rast/Makefile
M vector/v.what.rast3/Makefile
M vector/v.what.rast3/test_suite/random_points.txt
M vector/v.what.rast3/v.what.rast3.html
M vector/v.what/Makefile
M vector/v.what/v.what.html
M vector/vectorintro.html
Log Message:
Fix trailing whitespace, EOF and file formatting (#2785)
Updates .pre-commit-config.yaml file with list of files/directories to exclude.
Following pre-commit hooks are applied:
* trailing-whitespace
* end-of-file-fixer
* clang-format (now also formatting JavaScript, JSON and Objective-C files)
* markdownlint
