[GRASS-git] [OSGeo/grass] 19266d: contributing: Add suggest message to version scrip...
Vaclav Petras
noreply at github.com
Mon May 22 14:03:32 PDT 2023
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 19266d25f92212bd0e255bf68bb7c7dbf07fb7a2
https://github.com/OSGeo/grass/commit/19266d25f92212bd0e255bf68bb7c7dbf07fb7a2
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2023-05-22 (Mon, 22 May 2023)
Changed paths:
M utils/update_version.py
Log Message:
contributing: Add suggest message to version script (#2965)
The helper script for updates of versions suggests a commit message right after the update, but when additional changes need to be done, the message from the script can be lost. This adds a subcommand which can generate the message anytime. The message only makes sense when doing the version update, but the script does not check that. It also does not check (does not know) if the RC was just released. We use different commit message after that, but in that case, the commit happens right after the change from RC to dev, so there is no need to use this subcommand.
