[GRASS-git] [OSGeo/grass] 765b2e: libvector : reading files with 'struct Map_info*' ...
Nicklas Larsson
noreply at github.com
Tue Nov 21 01:15:54 PST 2023
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 765b2e9c0a2d9346d0d593be65b253068f3e5606
https://github.com/OSGeo/grass/commit/765b2e9c0a2d9346d0d593be65b253068f3e5606
Author: Nicklas Larsson <n_larsson at yahoo.com>
Date: 2023-11-21 (Tue, 21 Nov 2023)
Changed paths:
M include/grass/defs/vector.h
M lib/vector/Vlib/area.c
M lib/vector/Vlib/area_pg.c
M lib/vector/Vlib/array.c
M lib/vector/Vlib/box.c
M lib/vector/Vlib/buffer2.c
M lib/vector/Vlib/build.c
M lib/vector/Vlib/build_sfa.c
M lib/vector/Vlib/cindex.c
M lib/vector/Vlib/close.c
M lib/vector/Vlib/constraint.c
M lib/vector/Vlib/copy.c
M lib/vector/Vlib/dbcolumns.c
M lib/vector/Vlib/field.c
M lib/vector/Vlib/geos_to_wktb.c
M lib/vector/Vlib/header.c
M lib/vector/Vlib/header_finfo.c
M lib/vector/Vlib/hist.c
M lib/vector/Vlib/init_head.c
M lib/vector/Vlib/level.c
M lib/vector/Vlib/level_two.c
M lib/vector/Vlib/line.c
M lib/vector/Vlib/local_proto.h
M lib/vector/Vlib/net_analyze.c
M lib/vector/Vlib/open.c
M lib/vector/Vlib/pg_local_proto.h
M lib/vector/Vlib/poly.c
M lib/vector/Vlib/read.c
M lib/vector/Vlib/read_ogr.c
M lib/vector/Vlib/simple_features.c
M lib/vector/Vlib/write.c
M lib/vector/Vlib/write_nat.c
M lib/vector/Vlib/write_pg.c
M vector/v.colors/local_proto.h
M vector/v.colors/read_rgb.c
M vector/v.colors/scan_attr.c
M vector/v.colors/scan_cats.c
M vector/v.colors/write_rgb.c
M vector/v.decimate/copy_tab.c
M vector/v.decimate/main.c
M vector/v.distance/distance.c
M vector/v.distance/local_proto.h
M vector/v.extract/copy_tab.c
M vector/v.extract/local_proto.h
M vector/v.info/local_proto.h
M vector/v.info/print.c
M vector/v.out.postgis/local_proto.h
M vector/v.out.postgis/table.c
Log Message:
libvector : reading files with 'struct Map_info*' objects is technically not const (#2894)
The qualifier is removed from the API and code using it.
Co-authored-by: Māris Nartišs <maris.gis at gmail.com>
