[GRASS-git] [OSGeo/grass] 8bf604: g.mapsets: Add JSON output (#2542)
Corey White noreply at github.com
Thu Apr 11 04:56:52 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 8bf604c6447ab705907c47fa595079716f27226f
      https://github.com/OSGeo/grass/commit/8bf604c6447ab705907c47fa595079716f27226f
  Author: Corey White <smortopahri at gmail.com>
  Date:   2024-04-11 (Thu, 11 Apr 2024)
  Changed paths:
    M general/g.mapsets/Makefile
    M general/g.mapsets/g.mapsets.html
    M general/g.mapsets/list.c
    M general/g.mapsets/local_proto.h
    M general/g.mapsets/main.c
    A general/g.mapsets/tests/conftest.py
    A general/g.mapsets/tests/g_mapsets_list_format_test.py
  Log Message:
* g.mapsets: fixed indenting and added json flag  in preperation to add json output
* Added format options to list mapsets as plain, vertical, csv, or json
* g.mapsets: Added start testing listing mapsets with different formats
* g.mapsets: Reformated python with flake8 and black
* g.mapsets: Fixed indent conflict
* Fixed implicit declaration of function errors
* Fixed issues found in code review
* Added print flag to json output and added tests
* Simplified tests
* Apply clang format suggestions
Co-authored-by: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
* Updated code to use parson and fixed tests
* Updated docs
* Fixed mapsets array initalization issue
* Fixed bug setting JSON_ARRAY
* Removed unused parameter
* Update general/g.mapsets/main.c
Fixed typo.
Co-authored-by: Anna Petrasova <kratochanna at gmail.com>
* Updated default separator to space
Switch GUI section to Print
* Removed unneeded logic
* Update general/g.mapsets/list.c
Co-authored-by: Nicklas Larsson <n_larsson at yahoo.com>
* Implmented suggestion from code review
* Removed duplicate code
* Refactored duplicate code and removed some comments
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Co-authored-by: Corey White <ctwhite48 at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
