[GRASS-git] [OSGeo/grass] 4ba6ea: v.vol.rst: Update parameter names in the example (...
Loïc Bartoletti
noreply at github.com
Fri Apr 26 18:50:12 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 4ba6eaeb53b87fc725d2dde2e04785d2b2957b64
https://github.com/OSGeo/grass/commit/4ba6eaeb53b87fc725d2dde2e04785d2b2957b64
Author: Loïc Bartoletti <lbartoletti at users.noreply.github.com>
Date: 2024-04-26 (Fri, 26 Apr 2024)
Changed paths:
M vector/v.vol.rst/v.vol.rst.html
Log Message:
v.vol.rst: Update parameter names in the example (#3073)
Update code example according to the new parameters. Remove v.db.addcolumn because when the creation is left to v.to.db, no overwrite is needed. (>From v.to.db doc: The column will be created in the table if it doesn't already exist.)
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
