[GRASS-git] [OSGeo/grass] 8a05d9: grass.script: Remove copy-pasted code from tests (...
Vaclav Petras
noreply at github.com
Fri Apr 26 19:31:02 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 8a05d9faa1a6874b8a9fe013e3abcfa6ba7df1b1
https://github.com/OSGeo/grass/commit/8a05d9faa1a6874b8a9fe013e3abcfa6ba7df1b1
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2024-04-26 (Fri, 26 Apr 2024)
Changed paths:
M python/grass/script/tests/grass_script_core_location_test.py
Log Message:
grass.script: Remove copy-pasted code from tests (#3674)
While not harmful for what is tested, the code was copy-pasted from an unrelated test and is not needed in the given tests because init takes care of initialization in the desired location.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
