[GRASS-git] [OSGeo/grass] 46903c: style: Fix 12 ruff rules with small count of viola...
Edouard Choinière noreply at github.com
Wed Aug 14 14:19:23 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 46903c0e45c802f809645b745c59265ebc619c58
      https://github.com/OSGeo/grass/commit/46903c0e45c802f809645b745c59265ebc619c58
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Date:   2024-08-14 (Wed, 14 Aug 2024)
  Changed paths:
    M gui/wxpython/animation/dialogs.py
    M gui/wxpython/rdigit/toolbars.py
    M gui/wxpython/tplot/frame.py
    M gui/wxpython/web_services/dialogs.py
    M man/parser_standard_options.py
    M pyproject.toml
    M python/grass/gunittest/case.py
    M python/grass/jupyter/map3d.py
    M python/grass/pydispatch/saferef.py
    M python/grass/pygrass/utils.py
    M python/grass/pygrass/vector/testsuite/test_geometry.py
    M python/grass/script/core.py
    M python/grass/temporal/datetime_math.py
    M scripts/g.extension/g.extension.py
    M scripts/g.extension/testsuite/test_addons_download.py
  Log Message:
  style: Fix 12 ruff rules with small count of violations (#4139)
* style: Fix import-self (PLW0406)
Ruff rule: https://docs.astral.sh/ruff/rules/import-self/
1 instance solved
* Solve Pylint W0105: pointless-string-statement for python/grass/pygrass/utils.py
* Fix bad name of ruff rule in pyproject.toml
* Fix missing space in pyproject.toml ruff rules ignore list
* style: Fix native-literals (UP018)
* style: Fix unnecessary-dict-index-lookup (PLR1733)
* style: Fix no-classmethod-decorator (PLR0202)
Ruff rule: https://docs.astral.sh/ruff/rules/no-classmethod-decorator/
1 instance fixed.
* style: Ignore remaining comparison-with-itself (PLR0124) in test_eq
Ruff rule: https://docs.astral.sh/ruff/rules/comparison-with-itself/
1 instance solved
* style: Fix ambiguous-unicode-character-docstring (RUF002)
Ruff rule: https://docs.astral.sh/ruff/rules/ambiguous-unicode-character-docstring/
2 instances solved
* style: Fix unnecessary-generator-list (C400)
Ruff rule: https://docs.astral.sh/ruff/rules/unnecessary-generator-list/
1 instance solved
* style: Fix unnecessary-generator-set (C401)
Ruff rule: https://docs.astral.sh/ruff/rules/unnecessary-generator-set/
2 instances solved
* style: Fix unnecessary-list-comprehension-set (C403)
Ruff rule: https://docs.astral.sh/ruff/rules/unnecessary-list-comprehension-set/
3 instances solved
* style: Ignore 1 instance of sys-version-info-minor-cmp-int (YTT204)
Ruff rule:
https://docs.astral.sh/ruff/rules/sys-version-info-minor-cmp-int/
Correctly checks for only Python 3. Using a tuple would not be less messy, as a second comparison for >= Python 3.0 would be needed.
* style: Fix unnecessary-literal-set (C405)
Ruff rule: https://docs.astral.sh/ruff/rules/unnecessary-literal-set/
2 instances fixed
* Fix copy paste typo in ruff rule comment
* style: Fix implicit-optional (RUF013)
Ruff rule: https://docs.astral.sh/ruff/rules/implicit-optional/
2 instances fixed
* Update scripts/g.extension/g.extension.py
Co-authored-by: Stefan Blumentrath <stefan.blumentrath at gmx.de>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
