[GRASS-git] [OSGeo/grass-addons] 7bbd80: t.stac.import: Add STAC API import functionality (...
Corey White
noreply at github.com
Mon Aug 19 10:13:58 PDT 2024
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: 7bbd8051a38689885a89f25fd804ca9af125d837
https://github.com/OSGeo/grass-addons/commit/7bbd8051a38689885a89f25fd804ca9af125d837
Author: Corey White <smortopahri at gmail.com>
Date: 2024-08-19 (Mon, 19 Aug 2024)
Changed paths:
A src/temporal/t.stac/Makefile
A src/temporal/t.stac/README.md
A src/temporal/t.stac/libstac/Makefile
A src/temporal/t.stac/libstac/__init__.py
A src/temporal/t.stac/libstac/staclib.py
A src/temporal/t.stac/libstac/testsuite/test_staclib.py
A src/temporal/t.stac/requirements.txt
A src/temporal/t.stac/t.stac.catalog/Makefile
A src/temporal/t.stac/t.stac.catalog/t.stac.catalog.html
A src/temporal/t.stac/t.stac.catalog/t.stac.catalog.py
A src/temporal/t.stac/t.stac.catalog/testsuite/data/catalog.json
A src/temporal/t.stac/t.stac.catalog/testsuite/test_t_stac_catalog.py
A src/temporal/t.stac/t.stac.collection/Makefile
A src/temporal/t.stac/t.stac.collection/t.stac.collection.html
A src/temporal/t.stac/t.stac.collection/t.stac.collection.py
A src/temporal/t.stac/t.stac.collection/testsuite/test_t_stac_collection.py
A src/temporal/t.stac/t.stac.html
A src/temporal/t.stac/t.stac.item/Makefile
A src/temporal/t.stac/t.stac.item/t.stac.item.html
A src/temporal/t.stac/t.stac.item/t.stac.item.py
A src/temporal/t.stac/t.stac.item/testsuite/test_t_stac_item.py
Log Message:
t.stac.import: Add STAC API import functionality (#802)
* r.in.stac: inital setup of module structure options and flags
* Fixed formatting issues
* r.in.stac: added queries for collections and items
* Organized options
* t.stac.import: Changed module name to t.stac.import
* renamed grass to gs
* added get items function
* Added filter by bbox and user region
* Started the import and download fucntionallity
* fixed typo
* Added download method for COGs via https, s3, and gs
* Added query docs
* Updated multiprocessing options
* Started added static catalog functionality
* Updated docs
* Updated documentation
* Added authentication methods
* Added planetary computer support
* Cleaned code formatting
* Added ability to filter items assets by asset ids
* Improved collection outputs
* Added additional file types
* Started restructuring code into different modules
* Added t.stac.item
* Updated dependencies
* Fixed tests
* Added catalog tool
* Updted collection
* Updated docs
* Updated options
* Updated copyright
* Can import item vector boundary metadata
* Updated docs
* Added assest metadata vector
* Set s3 download parameters
* added format option
* Fixed item asset metadata
* Removed t.stac.import
* Added delete to tmpfile creation
* Removed references to t.stac.import
* Added mocked api tests
* Added checks for conformance classes
* Removed auth options from GUI
* Remove username param
* updated pystac and pystac-client versions, documenation and settings file
* Updated docs and basic output
* Added basic collection output
* Added option to create strd registry
* Updated max_limit to no default value
* Updated max_items default value
* Removed broken mock api tests
* Fixed formatting error
Co-authored-by: Corey White <ctwhite48 at gmail.com>
Co-authored-by: Veronica Andreo <veroandreo at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
