[GRASS-git] [OSGeo/grass] 603b4e: CI(OSGeo4w): Sort and split msys packages into sep...
Edouard Choinière
noreply at github.com
Thu Dec 5 03:58:32 PST 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 603b4e5341d896e23ad7797c600da1f58104f0fc
https://github.com/OSGeo/grass/commit/603b4e5341d896e23ad7797c600da1f58104f0fc
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2024-12-05 (Thu, 05 Dec 2024)
Changed paths:
M .github/workflows/osgeo4w.yml
Log Message:
CI(OSGeo4w): Sort and split msys packages into separate lines (#4747)
* CI(OSGeo4W): Split msys2 package list to separate sorted lines
* CI(OSGeo4W): Use pacboy to write shorter package names
The suffix `:p` means to install for the current env only (MINGW_PACKAGE_PREFIX). This allows to have the same package name for different msys2 environments
* CI(OSGeo4W): Remove pacboy suffixes
Not needed since https://github.com/msys2/pactoys/pull/6 changed the defaults when no suffix, and doesn't install for `mingw32` and `mingw64` anymore, only for the current env
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
