[GRASS-git] [OSGeo/grass] 161658: win: patch from OSGeo4W applied (#4121)
Martin Landa
noreply at github.com
Sun Dec 15 14:01:22 PST 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 161658b94c323fffa2db7ea3d1ffe7d54d05bff3
https://github.com/OSGeo/grass/commit/161658b94c323fffa2db7ea3d1ffe7d54d05bff3
Author: Martin Landa <landa.martin at gmail.com>
Date: 2024-12-15 (Sun, 15 Dec 2024)
Changed paths:
M .github/workflows/osgeo4w.yml
M mswindows/osgeo4w/build_osgeo4w.sh
M mswindows/osgeo4w/env.bat.tmpl
M mswindows/osgeo4w/libpng-config
M mswindows/osgeo4w/package.sh
Log Message:
* patch from https://github.com/jef-n/OSGeo4W/blob/master/src/grass/osgeo4w/patch applied
* attempt to fix osgeo4w CI
* re-introduce mingw-w64-x86_64-libpng
* sync with osgeo4w patch
* add NumPy into deps in order to fix some tests
* CI(OSGeo4W): Sort OSGeo4W packages in a multiline list
* Add back matplotlib package
* style: Sort packages and configure flags in mswindows build scripts
* packaging: Removed changes from patch that was removed upstream
https://github.com/jef-n/OSGeo4W/commit/c678c71d080e5c33e8cb64b12386be2ca4b6c54a
* packaging: Apply upstream patch update
https://github.com/jef-n/OSGeo4W/commit/4bd721f07ac8036274328a9e4500c1fa944a0926
* packaging: Keep --with-libpng with libpng-config from repo
* CI: Split msys2 packages on multiple lines, using pacboy for environment-specific packages
* Remove DLL list as unused after applying latest patch
The dll files are copied with the following line, which doesn't need to use that list anymore
# copy dependencies
cp -uv $(/usr/bin/find apps/grass/grass$POSTFIX -iname "*.dll" -o -iname "*.exe" | PATH=$PWD/apps/grass/grass$POSTFIX/lib:$PWD/bin:/mingw64/bin:/usr/bin /usr/bin/xargs /usr/bin/ldd | /usr/bin/sed -ne 's#^.* => \(/mingw64/bin/.*\) (.*)$#\1#p' | /usr/bin/sort -u) apps/grass/grass$POSTFIX/bin
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Co-authored-by: Jürgen Fischer <jef at norbit.de>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
