[GRASS-git] [OSGeo/grass-addons] 02f9ac: v.boxplot and r.boxplot: plot/layout options added...
Paulo van Breugel
noreply at github.com
Tue Dec 24 09:47:33 PST 2024
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: 02f9ac34d4b201a241d6ec3774398767c2b2fdbe
https://github.com/OSGeo/grass-addons/commit/02f9ac34d4b201a241d6ec3774398767c2b2fdbe
Author: Paulo van Breugel <paulo at ecodiv.earth>
Date: 2024-12-24 (Tue, 24 Dec 2024)
Changed paths:
M src/raster/r.boxplot/r.boxplot.html
M src/raster/r.boxplot/r.boxplot.py
M src/vector/v.boxplot/v.boxplot.html
M src/vector/v.boxplot/v.boxplot.py
Log Message:
v.boxplot and r.boxplot: plot/layout options added / changed (#1271)
* v.boxplot and r.boxplot: plot/layout options added / changed
Following suggestions in #1071
- Adding plot and layout options to v.boxplot
- Changes in parameter names of v.boxplot and r.boxplot
* v.boxplot: add layout/plot options
- Add option
- to set limits of value axis
- add grid lines
- Reorganize tabs
- Lazy loading matplotlib
- Fix: selected colors checked and changed to matplotlib format
* v.boxplot and r.boxplot: solve issue with running addons in VS Code
Running the addons in VS Code results in an error related with `matplotlib.use("WXAgg")`. A possible solution is using another backend like `WebAgg`. However, running VS Code probably means one wants to print the resulting graph to file. As in that case, the backend is not needed, we can just avoid loading it when the option to save the graph to file is selected.
* correction code
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
