[GRASS-git] [OSGeo/grass] b22477: contributing: Add API to check PR titles (#3824)
Vaclav Petras
noreply at github.com
Sat Jun 15 00:02:30 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: b224770c52870a171c2b7f500a7debbe862463de
https://github.com/OSGeo/grass/commit/b224770c52870a171c2b7f500a7debbe862463de
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2024-06-15 (Sat, 15 Jun 2024)
Changed paths:
M utils/generate_release_notes.py
Log Message:
This extends the API of the release notes generator to check a string (title) provided in command line against the categories provided in utils/release.yml. If there is no match, a message is printed and the process exits with non-zero return code. There is category "other changes", so non-zero may or may not mean a failure.
This does not do the checking, only provides the API to implement it.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
