[GRASS-git] [OSGeo/grass] 6f0ecc: CI: Switch Travis to Ubuntu 22.04 and fix non-prot...
Vaclav Petras
noreply at github.com
Wed Jun 19 02:30:39 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 6f0eccbe34e5e0f26785f3badfb0f1d46443dddb
https://github.com/OSGeo/grass/commit/6f0eccbe34e5e0f26785f3badfb0f1d46443dddb
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2024-06-19 (Wed, 19 Jun 2024)
Changed paths:
M .travis.yml
M .travis/linux.before_install.sh
M .travis/linux.install.sh
M .travis/linux.script.sh
M db/drivers/odbc/describe.c
M db/drivers/odbc/fetch.c
M db/drivers/odbc/listtab.c
Log Message:
CI: Switch Travis to Ubuntu 22.04 and fix non-prototype in ODBC (#3002)
* CI: Switch Travis to Ubuntu 22.04 (jammmy)
Default Python version reported by Travis for 20.04 is 3.7.13. While that's still a supported version for 8.3 release if it would be released now, 2023-06-27 is end of support for 3.7, so it seems safe to not test the main branch with 3.7 at this point.
Ubuntu 22.04 in Travis uses Python 3.10 by default according to the documentation.
* Update wxgtk pkg to 4.0
* Replace custom install list by apt.txt file from GitHub Actions
* Change shebang to use bash instead of POSIX sh (#3)
* CI(travis): Add --with-pdal in linux.script.sh
* CI(travis): Remove sudo: required as it has no effect
* CI(travis): Fix warning os and dist missing from root
* CI(travis): Fix warning matrix is an alias for jobs
* CI(travis): Run make with make -j $(nproc)
* CI(travis): Show MAKEFLAGS at start of script
* CI(travis): use c++17 standard
* CI(travis): Remove duplicated dist key in include array
* CI(travis): Remove invalid --with-python from configure flags
* CI(travis): Remove unused codecov upload
* CI(travis): Remove irc notification
* CI(travis): Add -Werror and -fPIC to CFLAGS and CXXFLAGS on make call
* CI(travis): Limit runs on branches to main and release branches
* CI(travis): Add -Wfatal-errors
* db: Fix -Wdeprecated-non-prototype in describe.c for clang builds
* CI(travis): Add --no-keep-going in MAKEFLAGS to stop on errors
* db: Fix -Wdeprecated-non-prototype in odbc driver's fetch.c for clang builds
* db: Fix -Wdeprecated-non-prototype in odbc driver's listtab.c for clang builds
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
