[GRASS-git] [OSGeo/grass] 784741: CI(deps): Update pre-commit hook pycqa/flake8 to v...
Edouard Choinière
noreply at github.com
Wed Jun 19 13:26:11 PDT 2024
Branch: refs/heads/renovate/docker-dockerfile-1.8
Home: https://github.com/OSGeo/grass
Commit: 784741708f46e1d43b5da868296e232620d6a4c7
https://github.com/OSGeo/grass/commit/784741708f46e1d43b5da868296e232620d6a4c7
Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Date: 2024-06-19 (Wed, 19 Jun 2024)
Changed paths:
M .pre-commit-config.yaml
Log Message:
CI(deps): Update pre-commit hook pycqa/flake8 to v7 (#3855)
Co-authored-by: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Commit: 6f0eccbe34e5e0f26785f3badfb0f1d46443dddb
https://github.com/OSGeo/grass/commit/6f0eccbe34e5e0f26785f3badfb0f1d46443dddb
Author: Vaclav Petras <wenzeslaus at gmail.com>
Changed paths:
M .travis.yml
M .travis/linux.before_install.sh
M .travis/linux.install.sh
M .travis/linux.script.sh
M db/drivers/odbc/describe.c
M db/drivers/odbc/fetch.c
M db/drivers/odbc/listtab.c
Log Message:
CI: Switch Travis to Ubuntu 22.04 and fix non-prototype in ODBC (#3002)
* CI: Switch Travis to Ubuntu 22.04 (jammmy)
Default Python version reported by Travis for 20.04 is 3.7.13. While that's still a supported version for 8.3 release if it would be released now, 2023-06-27 is end of support for 3.7, so it seems safe to not test the main branch with 3.7 at this point.
Ubuntu 22.04 in Travis uses Python 3.10 by default according to the documentation.
* Update wxgtk pkg to 4.0
* Replace custom install list by apt.txt file from GitHub Actions
* Change shebang to use bash instead of POSIX sh (#3)
* CI(travis): Add --with-pdal in linux.script.sh
* CI(travis): Remove sudo: required as it has no effect
* CI(travis): Fix warning os and dist missing from root
* CI(travis): Fix warning matrix is an alias for jobs
* CI(travis): Run make with make -j $(nproc)
* CI(travis): Show MAKEFLAGS at start of script
* CI(travis): use c++17 standard
* CI(travis): Remove duplicated dist key in include array
* CI(travis): Remove invalid --with-python from configure flags
* CI(travis): Remove unused codecov upload
* CI(travis): Remove irc notification
* CI(travis): Add -Werror and -fPIC to CFLAGS and CXXFLAGS on make call
* CI(travis): Limit runs on branches to main and release branches
* CI(travis): Add -Wfatal-errors
* db: Fix -Wdeprecated-non-prototype in describe.c for clang builds
* CI(travis): Add --no-keep-going in MAKEFLAGS to stop on errors
* db: Fix -Wdeprecated-non-prototype in odbc driver's fetch.c for clang builds
* db: Fix -Wdeprecated-non-prototype in odbc driver's listtab.c for clang builds
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Commit: 9564852ce5274e529006579e5d926387ff639f9b
https://github.com/OSGeo/grass/commit/9564852ce5274e529006579e5d926387ff639f9b
Changed paths:
M python/grass/experimental/tests/conftest.py
M python/grass/experimental/tests/grass_script_mapset_session_test.py
M python/grass/script/setup.py
M python/grass/script/tests/grass_script_core_location_test.py
M python/grass/script/tests/grass_script_setup_test.py
M scripts/v.db.univar/tests/conftest.py
M scripts/v.db.univar/tests/v_db_univar_test.py
M scripts/v.dissolve/tests/conftest.py
M scripts/v.dissolve/tests/v_dissolve_aggregate_test.py
M scripts/v.dissolve/tests/v_dissolve_geometry_test.py
M scripts/v.dissolve/tests/v_dissolve_layers_test.py
M scripts/v.dissolve/tests/v_dissolve_test.py
M temporal/t.rast.list/tests/conftest.py
M temporal/t.rast.list/tests/t_rast_list_test.py
M vector/v.fill.holes/tests/conftest.py
M vector/v.fill.holes/tests/v_fill_holes_test.py
Log Message:
grass.script: Allow init to modify only specified environment (#3438)
The _grass.script.setup.init_ function modifies os.environ. While os.environ is fit for many, if not most, cases, usage in tests and parallel processing is limited and in all cases, os.environ stays partially modified even after session is finished (we don't destroy the runtime environment, i.e., variables such as GISBASE). With this change, _init_ takes _env_ parameter specifying the environment to modify and it modifies that environment. When no _env_ is provided, it still modifies os.environ, so the default behavior is not changed.
This required only few changes to the initialization code, but more changes were needed for the cleanup code. A lot of tests can now take advantage of this functionality and this PR updates some of them. I plan to update all where it is applicable, but will leave as is some others, namely those which use ctypes (situation is more complex there) and _grass.jupyter_ (_env_ parameter is not implemented for most of them).
There is plenty of tests covering it, but the cleanup part which needed most changes does not have any coverage. I don't think there is much concern in terms of API because _env_ parameters is what we now have in many functions. The only uncertainty with that is whether it should create its own copy or modify the provided environment. I go with modify because that makes the copy explicit in the call which is more clear (caller or reader is sure a copy is created) and it is consistent with how os.environ is modified.
Commit: afd76107b0235d29c6eb7cff7b78f456922dc32b
https://github.com/OSGeo/grass/commit/afd76107b0235d29c6eb7cff7b78f456922dc32b
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Changed paths:
M .github/workflows/pytest.yml
M pyproject.toml
M python/grass/pygrass/modules/tests/grass_pygrass_grid_test.py
Log Message:
CI(pytest): Run tests marked need_solo_run separately (#3879)
* pytest: Create slow and needs_solo_run markers
* python: Apply needs_solo_run marker to two pygrass grid tests
* CI(pytest): Run tests marked need_solo_run separately with a single runner
* pytest: Revert timeout to 300 seconds
Commit: 7673b8099049ca5fdceee13c4fb17ea1795c5951
https://github.com/OSGeo/grass/commit/7673b8099049ca5fdceee13c4fb17ea1795c5951
Author: Ondrej Pesek <pesej.ondrek at gmail.com>
Changed paths:
M gui/wxpython/gmodeler/dialogs.py
Log Message:
wxGUI/gmodeler: fix conflicting flags in 'Create relation' dialog (#3865)
* wxGUI/gmodeler: fix conflicting flags in 'Create relation' dialog
* meanwhile, fix the button size to see them in the default pop-up
* fix #3862
Commit: 982b9b1339b0e2c11baf0f9ef79b373a3ee29c89
https://github.com/OSGeo/grass/commit/982b9b1339b0e2c11baf0f9ef79b373a3ee29c89
Changed paths:
M .github/workflows/periodic_update.yml
Log Message:
CI(deps): Update peter-evans/create-pull-request action to v6.1.0 (#3895)
Commit: 55b14b176b94d9d5422dffd17b1d06b21d721fca
https://github.com/OSGeo/grass/commit/55b14b176b94d9d5422dffd17b1d06b21d721fca
Changed paths:
M gui/wxpython/gmodeler/panels.py
Log Message:
wxGUI/gmodeler: fix adding data from menu (#3881)
* fix #3863
Commit: 7a7114697b345673eae10f5b6d246b75d587cb6d
https://github.com/OSGeo/grass/commit/7a7114697b345673eae10f5b6d246b75d587cb6d
Changed paths:
M .travis.yml
M pyproject.toml
Log Message:
Merge branch 'main' into renovate/docker-dockerfile-1.8
Compare: https://github.com/OSGeo/grass/compare/236fe0544dbd...7a7114697b34
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
