[GRASS-git] [OSGeo/grass] cfd6f9: CI(deps): Update pre-commit hook pre-commit/mirror...
Edouard Choinière
noreply at github.com
Fri Jun 21 13:40:15 PDT 2024
Branch: refs/heads/renovate/pre-commit-mirrors-clang-format-17.x
Home: https://github.com/OSGeo/grass
Commit: cfd6f9503d7cc0819c0437fc0702e68044652dfe
https://github.com/OSGeo/grass/commit/cfd6f9503d7cc0819c0437fc0702e68044652dfe
Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
Date: 2024-06-21 (Fri, 21 Jun 2024)
Changed paths:
M .pre-commit-config.yaml
Log Message:
CI(deps): Update pre-commit hook pre-commit/mirrors-clang-format to v17
Commit: 87ee82605800727c9fc8ace964291aca8e748a4e
https://github.com/OSGeo/grass/commit/87ee82605800727c9fc8ace964291aca8e748a4e
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Changed paths:
M .github/workflows/clang-format-check.yml
Log Message:
Update clang-format version to 17 in clang-format-check.yml
Commit: fed55520c7f81fb0b997d432a8a60b136426f58a
https://github.com/OSGeo/grass/commit/fed55520c7f81fb0b997d432a8a60b136426f58a
Changed paths:
M general/g.region/printwindow.c
M imagery/i.eb.netrad/r_net.c
M imagery/i.fft/main.c
M imagery/i.ifft/main.c
M imagery/i.maxlik/invert.c
M imagery/i.segment/flag.h
M include/grass/gprojects.h
M lib/bitmap/bitmap.c
M lib/bitmap/sparse.c
M lib/external/parson/parson.c
M lib/gis/lrand48.c
M lib/gis/lz4.c
M lib/gis/pi.h
M lib/gis/sleep.c
M lib/gmath/solvers_direct.c
M lib/gpde/test/test_arrays.c
M lib/ogsf/gs2.c
M lib/ogsf/gsget.h
M lib/ogsf/rgbpack.h
M lib/ogsf/rowcol.h
M lib/raster/get_row.c
M lib/rst/interp_float/segmen2d_parallel.c
M lib/vector/Vlib/intersect2.c
M lib/vector/dglib/graph_v1.h
M lib/vector/diglib/prune.c
M misc/m.cogo/main.c
M raster/r.buffer/distance.h
M raster/r.cost/flag.h
M raster/r.cost/heap.c
M raster/r.mfilter/execute.c
M raster/r.proj/main.c
M raster/r.random.cells/flag.h
M raster/r.random.cells/ransurf.h
M raster/r.random.surface/ransurf.h
M raster/r.ros/main.c
M raster/r.ros/spot_dist.c
M raster/r.sim/simlib/hydro.c
M raster/r.slope.aspect/main.c
M raster/r.spread/collect_ori.c
M raster/r.spread/main.c
M raster/r.spread/ram2out.c
M raster/r.spread/select_linksB.c
M raster/r.spread/spot.c
M raster/r.spread/spread.c
M raster/r.stream.extract/local_proto.h
M raster/r.sun/main.c
M raster/r.surf.contour/flag.h
M raster/r.surf.idw/pi.h
M raster/r.to.vect/areas.c
M raster/r.transect/parse_line.c
M raster/r.walk/flag.h
M raster/r.walk/heap.c
M raster/r.water.outlet/ramseg.h
M raster/r.watershed/ram/do_astar.h
M raster/r.watershed/ram/flag.h
M raster/r.watershed/ram/ramseg.h
M vector/v.cluster/main.c
M vector/v.label.sa/labels.c
Log Message:
Formatted files with clang-format 17
Compare: https://github.com/OSGeo/grass/compare/5e99d41ad6a6...fed55520c7f8
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
