[GRASS-git] [OSGeo/grass] f825a2: v.surf.rst: Cross-validation OpenMP support (#3590)
Chung-Yuan Liang
noreply at github.com
Mon Jun 24 10:24:14 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: f825a223c28f7cd5ab6d075bd02b8f5e73956c4a
https://github.com/OSGeo/grass/commit/f825a223c28f7cd5ab6d075bd02b8f5e73956c4a
Author: Chung-Yuan Liang <77927944+cyliang368 at users.noreply.github.com>
Date: 2024-06-24 (Mon, 24 Jun 2024)
Changed paths:
M lib/rst/interp_float/interpf.h
M lib/rst/interp_float/point2d.c
A lib/rst/interp_float/point2d_parallel.c
M lib/rst/interp_float/ressegm2d.c
M lib/rst/interp_float/segmen2d.c
M lib/rst/interp_float/segmen2d_parallel.c
A vector/v.surf.rst/benchmark/benchmark_v_surf_rst.py
A vector/v.surf.rst/benchmark/benchmark_v_surf_rst_cv.py
M vector/v.surf.rst/main.c
M vector/v.surf.rst/testsuite/test_vsurfrst.py
M vector/v.surf.rst/v.surf.rst.html
A vector/v.surf.rst/vsurfrst_benchmark.png
A vector/v.surf.rst/vsurfrst_cv_benchmark.png
Log Message:
* v.surf.rst: cv openmp support
* Update main.c
Use /* ... */ instead of // for consistency and compatibility with pre-99 C standard (https://gcc.gnu.org/onlinedocs/gcc/C_002b_002b-Comments.html)
* Update main.c
Fix a string in `#if 0`
* Update vector/v.surf.rst/main.c
clang-format
* v.surf.rst: devi openmp support
* Update profile.sh
remove nproc argument
* Apply suggestions from code review
* v.surf.rst: parallelize point2d.c
* v.surf.rst: add tests for multithread cv & dev
* v.surf.rst: point2d_parallel.c, function, test updates
* clean formats
* update document and remove unused lines
* replace replicate part in point2d.c by write_point_2d
* add benchmark for parallelization
* remove unused variables in point2d.c
* remove c-flag from vsurfrst.py benchmark
Co-authored-by: Anna Petrasova <kratochanna at gmail.com>
* correct the number in the label in benchmark_v_surf_rst_cv.py
* include benmarks into the document page
* remove unnecessary changes in the html file
* remove syntax error in v.surf.rst.html
* revise performance and author sections in the html file
* remove invalid syntax in the html file
* revise the description of performance in the html file
* breakdown long lines in v.surf.rst.html
Co-authored-by: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
Co-authored-by: Huidae Cho <grass4u at gmail.com>
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
