[GRASS-git] [OSGeo/grass] 2e296b: CI(deps): Update pre-commit hook pre-commit/mirror...
Edouard Choinière noreply at github.com
Tue Jun 25 13:44:14 PDT 2024
  Branch: refs/heads/renovate/pre-commit-mirrors-clang-format-17.x
  Home:   https://github.com/OSGeo/grass
  Commit: 2e296b70c1b566e65a28e75fb814c42dfc0000f4
      https://github.com/OSGeo/grass/commit/2e296b70c1b566e65a28e75fb814c42dfc0000f4
  Author: renovate[bot] <29139614+renovate[bot]@users.noreply.github.com>
  Date:   2024-06-25 (Tue, 25 Jun 2024)
  Changed paths:
    M .pre-commit-config.yaml
  Log Message:
  CI(deps): Update pre-commit hook pre-commit/mirrors-clang-format to v17
  Commit: d0f1af6f8c66980c867247ef9af8e4831cc71b0f
      https://github.com/OSGeo/grass/commit/d0f1af6f8c66980c867247ef9af8e4831cc71b0f
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Changed paths:
    M .github/workflows/clang-format-check.yml
  Log Message:
  Update clang-format version to 17 in clang-format-check.yml
  Commit: c89460bcd310063cd0af8ef5b8ba90f1b21b0055
      https://github.com/OSGeo/grass/commit/c89460bcd310063cd0af8ef5b8ba90f1b21b0055
  Changed paths:
    M general/g.region/printwindow.c
    M imagery/i.eb.netrad/r_net.c
    M imagery/i.fft/main.c
    M imagery/i.ifft/main.c
    M imagery/i.maxlik/invert.c
    M imagery/i.segment/flag.h
    M include/grass/gprojects.h
    M lib/bitmap/bitmap.c
    M lib/bitmap/sparse.c
    M lib/external/parson/parson.c
    M lib/gis/lrand48.c
    M lib/gis/lz4.c
    M lib/gis/pi.h
    M lib/gis/sleep.c
    M lib/gmath/solvers_direct.c
    M lib/gpde/test/test_arrays.c
    M lib/ogsf/gs2.c
    M lib/ogsf/gsget.h
    M lib/ogsf/rgbpack.h
    M lib/ogsf/rowcol.h
    M lib/raster/get_row.c
    M lib/rst/interp_float/segmen2d_parallel.c
    M lib/vector/Vlib/intersect2.c
    M lib/vector/dglib/graph_v1.h
    M lib/vector/diglib/prune.c
    M misc/m.cogo/main.c
    M raster/r.buffer/distance.h
    M raster/r.cost/flag.h
    M raster/r.cost/heap.c
    M raster/r.mfilter/execute.c
    M raster/r.proj/main.c
    M raster/r.random.cells/flag.h
    M raster/r.random.cells/ransurf.h
    M raster/r.random.surface/ransurf.h
    M raster/r.ros/main.c
    M raster/r.ros/spot_dist.c
    M raster/r.sim/simlib/hydro.c
    M raster/r.slope.aspect/main.c
    M raster/r.spread/collect_ori.c
    M raster/r.spread/main.c
    M raster/r.spread/ram2out.c
    M raster/r.spread/select_linksB.c
    M raster/r.spread/spot.c
    M raster/r.spread/spread.c
    M raster/r.stream.extract/local_proto.h
    M raster/r.sun/main.c
    M raster/r.surf.contour/flag.h
    M raster/r.surf.idw/pi.h
    M raster/r.to.vect/areas.c
    M raster/r.transect/parse_line.c
    M raster/r.walk/flag.h
    M raster/r.walk/heap.c
    M raster/r.water.outlet/ramseg.h
    M raster/r.watershed/ram/do_astar.h
    M raster/r.watershed/ram/flag.h
    M raster/r.watershed/ram/ramseg.h
    M vector/v.cluster/main.c
    M vector/v.label.sa/labels.c
  Log Message:
  Formatted files with clang-format 17
Compare: https://github.com/OSGeo/grass/compare/d10244a5f5a6...c89460bcd310
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
