[GRASS-git] [OSGeo/grass] 4f1b89: style(temporal): Sort and group imports (#3959)
Edouard Choinière noreply at github.com
Sun Jun 30 23:11:20 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 4f1b89778884a93b160d89019a5993cee94033a8
      https://github.com/OSGeo/grass/commit/4f1b89778884a93b160d89019a5993cee94033a8
  Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
  Date:   2024-07-01 (Mon, 01 Jul 2024)
  Changed paths:
    M python/grass/temporal/__init__.py
    M python/grass/temporal/abstract_dataset.py
    M python/grass/temporal/abstract_map_dataset.py
    M python/grass/temporal/abstract_space_time_dataset.py
    M python/grass/temporal/aggregation.py
    M python/grass/temporal/base.py
    M python/grass/temporal/c_libraries_interface.py
    M python/grass/temporal/core.py
    M python/grass/temporal/datetime_math.py
    M python/grass/temporal/extract.py
    M python/grass/temporal/factory.py
    M python/grass/temporal/gui_support.py
    M python/grass/temporal/list_stds.py
    M python/grass/temporal/mapcalc.py
    M python/grass/temporal/open_stds.py
    M python/grass/temporal/register.py
    M python/grass/temporal/sampling.py
    M python/grass/temporal/space_time_datasets.py
    M python/grass/temporal/spatio_temporal_relationships.py
    M python/grass/temporal/stds_export.py
    M python/grass/temporal/stds_import.py
    M python/grass/temporal/temporal_algebra.py
    M python/grass/temporal/temporal_granularity.py
    M python/grass/temporal/temporal_operator.py
    M python/grass/temporal/temporal_raster3d_algebra.py
    M python/grass/temporal/temporal_raster_algebra.py
    M python/grass/temporal/temporal_raster_base_algebra.py
    M python/grass/temporal/temporal_vector_algebra.py
    M python/grass/temporal/testsuite/test_register_function.py
    M python/grass/temporal/testsuite/test_temporal_doctests.py
    M python/grass/temporal/testsuite/unittests_temporal_algebra.py
    M python/grass/temporal/testsuite/unittests_temporal_algebra_grs.py
    M python/grass/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py
    M python/grass/temporal/testsuite/unittests_temporal_conditionals.py
    M python/grass/temporal/testsuite/unittests_temporal_raster3d_algebra.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_algebra.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_conditionals.py
    M python/grass/temporal/testsuite/unittests_temporal_raster_conditionals_complement_else.py
    M python/grass/temporal/testsuite/unittests_temporal_vector_algebra.py
    M python/grass/temporal/unit_tests.py
    M temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
    M temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
    M temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
    M temporal/t.copy/t.copy.py
    M temporal/t.list/t.list.py
    M temporal/t.merge/t.merge.py
    M temporal/t.rast.accdetect/t.rast.accdetect.py
    M temporal/t.rast.accdetect/testsuite/test_simple.py
    M temporal/t.rast.accumulate/testsuite/test_accumulation.py
    M temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
    M temporal/t.rast.aggregate/t.rast.aggregate.py
    M temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
    M temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
    M temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
    M temporal/t.rast.algebra/t.rast.algebra.py
    M temporal/t.rast.algebra/testsuite/test_raster_algebra_arithmetic.py
    M temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
    M temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
    M temporal/t.rast.algebra/testsuite/test_raster_algebra_operators.py
    M temporal/t.rast.contour/t.rast.contour.py
    M temporal/t.rast.export/t.rast.export.py
    M temporal/t.rast.export/testsuite/test_rast_export.py
    M temporal/t.rast.extract/t.rast.extract.py
    M temporal/t.rast.extract/testsuite/test_t_rast_extract.py
    M temporal/t.rast.gapfill/t.rast.gapfill.py
    M temporal/t.rast.gapfill/testsuite/test_gapfill.py
    M temporal/t.rast.import/testsuite/test_temporal_rast_import.py
    M temporal/t.rast.list/tests/conftest.py
    M temporal/t.rast.mapcalc/t.rast.mapcalc.py
    M temporal/t.rast.neighbors/t.rast.neighbors.py
    M temporal/t.rast.neighbors/testsuite/test_neighbors.py
    M temporal/t.rast.out.vtk/t.rast.out.vtk.py
    M temporal/t.rast.series/testsuite/test_series.py
    M temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
    M temporal/t.rast.to.vect/t.rast.to.vect.py
    M temporal/t.rast.to.vect/testsuite/test_to_vect.py
    M temporal/t.rast.what/t.rast.what.py
    M temporal/t.rast3d.algebra/t.rast3d.algebra.py
    M temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
    M temporal/t.rast3d.extract/t.rast3d.extract.py
    M temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py
    M temporal/t.rast3d.list/t.rast3d.list.py
    M temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
    M temporal/t.rast3d.univar/t.rast3d.univar.py
    M temporal/t.register/t.register.py
    M temporal/t.register/testsuite/test_t_register_raster.py
    M temporal/t.register/testsuite/test_t_register_raster_different_local.py
    M temporal/t.register/testsuite/test_t_register_raster_file.py
    M temporal/t.register/testsuite/test_t_register_raster_mapmetadata.py
    M temporal/t.remove/t.remove.py
    M temporal/t.rename/testsuite/test_t_rename.py
    M temporal/t.sample/t.sample.py
    M temporal/t.select/t.select.py
    M temporal/t.shift/t.shift.py
    M temporal/t.shift/testsuite/test_shift.py
    M temporal/t.snap/t.snap.py
    M temporal/t.snap/testsuite/test_snap.py
    M temporal/t.support/t.support.py
    M temporal/t.support/testsuite/test_support_str3ds.py
    M temporal/t.support/testsuite/test_support_strds.py
    M temporal/t.support/testsuite/test_support_stvds.py
    M temporal/t.topology/t.topology.py
    M temporal/t.unregister/testsuite/test_unregister.py
    M temporal/t.vect.algebra/t.vect.algebra.py
    M temporal/t.vect.algebra/testsuite/test_vector_algebra.py
    M temporal/t.vect.db.select/t.vect.db.select.py
    M temporal/t.vect.extract/t.vect.extract.py
    M temporal/t.vect.list/t.vect.list.py
    M temporal/t.vect.univar/t.vect.univar.py
    M temporal/t.vect.what.strds/t.vect.what.strds.py
  Log Message:
* style(temporal): Sort and group imports
Uses a combination of `ruff check --output-format=concise --select I --fix 'temporal/' 'python/grass/temporal'`, `isort --profile=black temporal python/grass/temporal` and `black .`
* style(temporal): Sort and group imports for __init__.py
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
