[GRASS-git] [OSGeo/grass] 44ea59: grass.script: Provide env parameter in the g.messa...
Vaclav Petras
noreply at github.com
Sat Mar 2 19:10:54 PST 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 44ea5979147f3a2dcb8f1dcfd161d21e6a5b1962
https://github.com/OSGeo/grass/commit/44ea5979147f3a2dcb8f1dcfd161d21e6a5b1962
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2024-03-03 (Sun, 03 Mar 2024)
Changed paths:
M python/grass/script/core.py
Log Message:
grass.script: Provide env parameter in the g.message API (#3439)
This makes the _message_, _verbose_ and other functions consistent with other wrappers around _run_command_ family calls. While not needed for multiple-mapset situations and parallelization, it is necessary when calls with messages are used without global environment being set and only a custom (local) environment is available which is the case in grass.script.setup (with #3438).
The PR aims at providing the interface, not updating all use cases (it will be applied for grass.script.setup in #3438).
This does not have any test since the current API does not allow for writing these test. This will be tested indirectly in the future (e.g. by #3438).
Additionally, it fixes documentation for couple other function where the parameter documentation was misleading or wrong.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
