[GRASS-git] [OSGeo/grass] 4269a6: wxGUI/dbmgr: fix enclosing column name with SQL st...
Tomas Zigo noreply at github.com
Fri May 3 19:46:03 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 4269a67dfb47d61e61ea563d018ad846897d09b0
      https://github.com/OSGeo/grass/commit/4269a67dfb47d61e61ea563d018ad846897d09b0
  Author: Tomas Zigo <50632337+tmszi at users.noreply.github.com>
  Date:   2024-05-04 (Sat, 04 May 2024)
  Changed paths:
    M gui/wxpython/dbmgr/base.py
    M gui/wxpython/dbmgr/sqlbuilder.py
  Log Message:
  wxGUI/dbmgr: fix enclosing column name with SQL standard double quotes (#3634)
Enable to use (show/add/delete/rename/query) column name which is
reserved DB backend keyword.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
