[GRASS-git] [OSGeo/grass-addons] fe5896: cronjobs: expand script to run stand-alone (#1215)
Markus Neteler
noreply at github.com
Tue Nov 12 14:39:51 PST 2024
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: fe589635c6cb815d45ea60fc93df9bbf2c48513a
https://github.com/OSGeo/grass-addons/commit/fe589635c6cb815d45ea60fc93df9bbf2c48513a
Author: Markus Neteler <neteler at osgeo.org>
Date: 2024-11-12 (Tue, 12 Nov 2024)
Changed paths:
M utils/cronjobs_osgeo_lxd/README.md
M utils/cronjobs_osgeo_lxd/compile_addons_git.sh
M utils/cronjobs_osgeo_lxd/cron_grass_current_stable_build_binaries.sh
M utils/cronjobs_osgeo_lxd/cron_grass_current_stable_src_snapshot.sh
M utils/cronjobs_osgeo_lxd/cron_grass_legacy_build_binaries.sh
M utils/cronjobs_osgeo_lxd/cron_grass_legacy_src_snapshot.sh
M utils/cronjobs_osgeo_lxd/cron_grass_old_build_binaries.sh
M utils/cronjobs_osgeo_lxd/cron_grass_old_src_snapshot.sh
M utils/cronjobs_osgeo_lxd/cron_grass_preview_build_binaries.sh
M utils/cronjobs_osgeo_lxd/cron_grass_preview_src_snapshot.sh
Log Message:
With this PR instructions to set up the source code repo have been turned into executable script chunks.
Hence, if the scripts are executed on a new server, the GitHub repo cloning is done as well as needed directories are created.
Furthermore, some minor script tuning:
* comment improvements
* define USER env by id command (Docker compliant)
* replace `~` with env var
* do not clone repo within scripts
* simplify instructions
* compile_addons_git.sh: run 2 make jobs in parallel
* accommodate for script path defined in grass-addons-index.sh
* README.md: add intro to docker section; make it stand-alone
Co-authored-by: Vaclav Petras <wenzeslaus at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
