[GRASS-git] [OSGeo/grass] b9a6b6: doc: Use lowercase for 2D raster mask (#4401)
Vaclav Petras noreply at github.com
Fri Oct 11 07:21:44 PDT 2024
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: b9a6b6883899e7611a2d65b63a1c02d6a50d59e4
      https://github.com/OSGeo/grass/commit/b9a6b6883899e7611a2d65b63a1c02d6a50d59e4
  Author: Vaclav Petras <wenzeslaus at gmail.com>
  Date:   2024-10-11 (Fri, 11 Oct 2024)
  Changed paths:
    M display/d.histogram/d.histogram.html
    M raster/r.circle/main.c
    M raster/r.external/r.external.html
    M raster/r.null/r.null.html
    M raster/r.stream.extract/r.stream.extract.html
    M raster3d/raster3dintro.html
    M scripts/r.out.xyz/r.out.xyz.html
  Log Message:
On many places (more than covered here), 2D raster mask is called MASK conflating the concept (mask) and the implementation (MASK raster). Users using the r.mask tool may not interact with the underlying raster directly, so there is no reason to use MASK over mask.
This is changing MASK to mask and modifies related wording. However, this is also leaving many places as they are with MASK. Some will be better revisited with or after #2390 and #2392 when a more comprehensive solution is available.
This fixes and keeps in sync wording in r.null and r.external, and moves r.circle comment documenting the interface to a flag description.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
