[GRASS-git] [OSGeo/grass] 7fbaa7: style: Enable checking for pep8-naming (N) rules w...
Edouard Choinière
noreply at github.com
Sun Oct 20 07:53:06 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 7fbaa7e5a1b7cfe4fa3701a4ecfef51547843269
https://github.com/OSGeo/grass/commit/7fbaa7e5a1b7cfe4fa3701a4ecfef51547843269
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2024-10-20 (Sun, 20 Oct 2024)
Changed paths:
M gui/wxpython/mapswipe/frame.py
M pyproject.toml
M python/grass/pygrass/modules/interface/testsuite/test_modules.py
M python/grass/script/tests/test_script_task.py
M raster/r.basins.fill/testsuite/testrbf.py
M raster/r.series/testsuite/test_r_series.py
M raster/r.terraflow/testsuite/test_r_terraflow.py
M raster/r.to.vect/testsuite/test_r_to_vect.py
M raster/r.viewshed/testsuite/test_r_viewshed.py
M scripts/r.import/testsuite/test_r_import.py
M scripts/r.reclass.area/testsuite/testrra.py
M scripts/v.import/testsuite/test_v_import.py
M vector/v.extract/testsuite/test_v_extract.py
M vector/v.net/testsuite/test_v_net.py
M vector/v.random/testsuite/test_v_random.py
M vector/v.select/testsuite/test_v_select.py
M vector/v.to.3d/testsuite/test_vto3d.py
Log Message:
style: Enable checking for pep8-naming (N) rules with ruff, fix N804, N805 and N813 (#4556)
* style: Enable checking for pep8-naming (N) rules with Ruff
Rules already respected:
- dunder-function-name (N807)
- constant-imported-as-non-constant (N811)
- camelcase-imported-as-acronym (N817)
* style: Fix invalid-first-argument-name-for-class-method (N804)
Ruff rule: https://docs.astral.sh/ruff/rules/invalid-first-argument-name-for-class-method/
Two files had class methods that didn't use cls as their first argument
* style: Fix camelcase-imported-as-lowercase (N813)
Ruff rule: https://docs.astral.sh/ruff/rules/camelcase-imported-as-lowercase/
One instance only in a pytest file
* style: Fix invalid-first-argument-name-for-method (N805)
Ruff rule: https://docs.astral.sh/ruff/rules/invalid-first-argument-name-for-method/
Three instances in gui/wxpython/mapswipe/frame.py were ignored, as an inner class is defined using self2 and also references self from the containing class.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
