[GRASS-git] [OSGeo/grass] 213f02: CI(macOS): Use micromamba-shell for steps to load ...
Edouard Choinière
noreply at github.com
Mon Sep 16 04:24:25 PDT 2024
Branch: refs/heads/renovate/ruff
Home: https://github.com/OSGeo/grass
Commit: 213f024ac4fc6275ad565688c7706a611c8ce56a
https://github.com/OSGeo/grass/commit/213f024ac4fc6275ad565688c7706a611c8ce56a
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2024-09-16 (Mon, 16 Sep 2024)
Changed paths:
M .github/workflows/macos.yml
Log Message:
CI(macOS): Use micromamba-shell for steps to load PATH changes (#4325)
Fixes problems with loading environment variables and path on the newest GitHub Actions macOS 20240911.3 runner image, that makes all builds fail.
* CI(macOS): Use micromamba-shell for build and install
* CI(macOS): Use micromamba-shell for printing versions
* CI(macOS): Use micromamba-shell for pytest and gunittest
Commit: 63a80f5c198a48ecf741a9bb97d6d37106651f12
https://github.com/OSGeo/grass/commit/63a80f5c198a48ecf741a9bb97d6d37106651f12
Author: Mohan Yelugoti <ymdatta.work at gmail.com>
Changed paths:
M lib/linkm/test/try.c
M lib/linkm/test/try2.c
Log Message:
lib/linkm: Change non-returning internal function types to void (#4318)
Commit: d0f1634cfe08ed6adda7ce2513d363898bf5b347
https://github.com/OSGeo/grass/commit/d0f1634cfe08ed6adda7ce2513d363898bf5b347
Changed paths:
M .github/workflows/osgeo4w.yml
Log Message:
CI(OSGeo4W): Add -pipe to CFLAGS and CXXFLAGS to reduce build time (#4326)
With the current GitHub Hosted runners, the build step time is reduced by about 2 minutes, down to about 8min30 instead of about 10min30, for the couple builds I observed
Commit: 6eeefe2f22f6a89d9bb11ea9514b76a31d5c2973
https://github.com/OSGeo/grass/commit/6eeefe2f22f6a89d9bb11ea9514b76a31d5c2973
Changed paths:
Log Message:
Merge branch 'main' into renovate/ruff
Compare: https://github.com/OSGeo/grass/compare/544e6dedf0e6...6eeefe2f22f6
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
