[GRASS-git] [OSGeo/grass] 7b4a24: tests: Add `xfail_windows` decorator for failing t...
Edouard Choinière
noreply at github.com
Sun Sep 22 05:28:29 PDT 2024
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: 7b4a2404a4fe9fe7cda1807f8ab144b02928d661
https://github.com/OSGeo/grass/commit/7b4a2404a4fe9fe7cda1807f8ab144b02928d661
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2024-09-22 (Sun, 22 Sep 2024)
Changed paths:
A .github/workflows/osgeo4w_gunittest.cfg
M .github/workflows/test_thorough.bat
M gui/wxpython/core/testsuite/test_gcmd.py
M imagery/i.maxlik/testsuite/test_i_maxlik.py
M lib/gis/testsuite/test_parser_json.py
M lib/imagery/testsuite/test_imagery_signature_management.py
M lib/init/testsuite/test_grass_tmp_mapset.py
M python/grass/grassdb/testsuite/test_manage.py
M python/grass/gunittest/testsuite/test_assertions.py
M python/grass/gunittest/testsuite/test_assertions_vect.py
M python/grass/gunittest/testsuite/test_checkers.py
M python/grass/gunittest/utils.py
M python/grass/jupyter/testsuite/map3d_test.py
M python/grass/pygrass/raster/testsuite/test_category.py
M python/grass/pygrass/raster/testsuite/test_numpy.py
M python/grass/pygrass/raster/testsuite/test_raster_img.py
M python/grass/script/testsuite/test_start_command_functions.py
M python/grass/script/testsuite/test_utils.py
M python/grass/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py
M raster/r.in.gdal/testsuite/test_r_in_gdal.py
M raster/r.kappa/testsuite/test_r_kappa.py
M raster/r.mfilter/testsuite/test_r_mfilter.py
M raster/r.report/testsuite/test_r_report.py
M scripts/g.extension/testsuite/test_addons_modules.py
M scripts/g.extension/testsuite/test_addons_toolboxes.py
M scripts/g.search.modules/testsuite/test_g_search_modules.py
M scripts/r.tileset/testsuite/test_r_tileset.py
M scripts/v.rast.stats/testsuite/test_v_rast_stats.py
M temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
M temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
M temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
M temporal/t.rast.gapfill/testsuite/test_gapfill.py
M temporal/t.rast.series/testsuite/test_series.py
M temporal/t.rast.univar/testsuite/test_t_rast_univar.py
M temporal/t.rast.what/testsuite/test_what.py
M temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py
M vector/v.out.lidar/testsuite/test_v_out_lidar.py
M vector/v.univar/testsuite/test_v_univar.py
Log Message:
tests: Add `xfail_windows` decorator for failing tests on Windows (#4362)
* grass.gunittest: Add xfail_windows decorator for Windows expected failures
* lib/imagery: Add xfail_windows decorator to test functions
* Fix spacing issue in xfail_windows warning message
* Add stacklevel=2 to xfail_windows decorator warning message
* Update utils.py
Co-authored-by: github-actions[bot] <41898282+github-actions[bot]@users.noreply.github.com>
* Format end of file
* Comment out warning in decorator
* i.maxlik: Add xfail_windows decorator to SuccessTest class
* lib/gis: Add xfail_windows decorator to TestNewlinesWithGetlFunctions class
* Update warning stacklevel to 3
* Update utils.py
* Update utils.py
* Update utils.py
* tests: Add expected failures to failing tests on windows
* tests: Apply xfail_windows decorator to setUpClass in lib/gis getl tests
* tests: Apply xfail_windows decorator to parser json tests in lib/gis
* tests: Apply xfail_windows decorator to failing test in lib/imagery
* Remove wrong import of xfail_windows
* tests: Temporarily remove all gunittest exclusions
* tests: Apply xfail_windows decorator to failing test in test_gcmd.py
* tests: Apply xfail_windows decorator to failing test in lib/init in test_grass_tmp_mapset.py
* CI(OSGeo4W): Use an OSGeo4W-specific gunittest.cfg config file
* Revert "tests: Temporarily remove all gunittest exclusions"
This reverts commit 20eb947d4cc0f1b2f79ffb9e16541fcb94d59a9a.
* v.out.lidar: Apply xfail_windows decorator to one failing test
* t.rast.series: Apply xfail_windows decorator to failing tests
* t.connect: Apply xfail_windows decorator to three failing tests
* g.search.modules: Apply xfail_windows decorator to a failing test
* grass.temporal: Apply xfail_windows decorator to failing tests in unittests_temporal_raster_algebra_equal_ts
* grass.gunittest: Apply xfail_windows decorator to failing test test_assertVectorEqualsAscii_by_import
* tests: Re-enable excluded tests that are not failing on Windows
* tests: Re-enable passing tests from .gunittest.cfg exclusion list
* Update test_gis_lib_getl.py
* Update test_raster_img.py
* tests: Try re-enabling python/grass/script/testsuite/test_script_doctests.py
* i.maxlik: Add xfail_windows decorator to all tests in class
* tests: Exclude more tests that are failing on Windows
* v.univar: Apply xfail_windows decorator to failing tests
* t.rast.univar: Apply xfail_windows decorator to a failing test
* r.in.gdal: Try avoiding error in calling gdal-config in skipif decorator on Windows
* CI(OSGeo4W): Increase min-success to 96% for gunittest
* Add line in test_grass_tmp_mapset.py
* Update test_r_tileset.py
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
