[GRASS-git] [OSGeo/grass] a426d4: grass.script: Add separate function to sort throug...
Vaclav Petras
noreply at github.com
Wed Apr 23 16:00:24 PDT 2025
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: a426d429c35b97e482b080dc08b8ae3513e85126
https://github.com/OSGeo/grass/commit/a426d429c35b97e482b080dc08b8ae3513e85126
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2025-04-23 (Wed, 23 Apr 2025)
Changed paths:
M python/grass/script/__init__.py
M python/grass/script/core.py
Log Message:
grass.script: Add separate function to sort through run_command style parameters (#5582)
Parameters for the run_command family of functions are a mix of Popen parameters and Python-ified parameters of a tool. This refactors the splitting functionality into a separate function allowing for use without the actual Popen call which is part of start_command. This is useful whan you need to call Popen or subprocess.run by yourself, but still want the run_command syntax.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
