[GRASS-git] [OSGeo/grass-addons] abbdb3: cronjobs: script to retrieve and unpack manual art...
Markus Neteler
noreply at github.com
Sun Aug 3 13:38:32 PDT 2025
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: abbdb350e6c443969a92a65d84c72cc1e8da770c
https://github.com/OSGeo/grass-addons/commit/abbdb350e6c443969a92a65d84c72cc1e8da770c
Author: Markus Neteler <neteler at osgeo.org>
Date: 2025-08-03 (Sun, 03 Aug 2025)
Changed paths:
M utils/cronjobs_osgeo_lxd/cron_job_list_grass
A utils/cronjobs_osgeo_lxd/fetch_unpack_manual_GHA.sh
A utils/cronjobs_osgeo_lxd/gh_cli_download_artifact.sh
Log Message:
cronjobs: script to retrieve and unpack manual artifacts from GitHub (#1447)
* cronjobs: new script to retrieve manual artifacts from GitHub on OSGeo servers
The mkdocs based manual pages (currently the GRASS 8.5 main branch) are generated as a ZIP file through the GitHub Actions.
This ZIP file needs then to be transferred and unpacked in the related directories on grass.osgeo.org/ and download.osgeo.org/grass/.
This script downloads the latest "mkdocs-site" ZIP artifact from the "documentation.yml" workflow runs.
How this script works:
- the person to execute this script needs to generate a new read-only token: https://github.com/settings/personal-access-tokens
- the person to execute this script on the GRASS/OSGeo servers needs to `cd` to the repo; login via gh auth login using the token
- CAVEAT: these tokens expire after three months! - unsolved problem at time
- in this script:
- the last successful workflow run is identified via GH CLI
- artifacts for this run are looked up
- the artifact is downloaded as ZIP file (takes a moment)
Eventually the ZIP archive needs to be unpacked in the right server directory (done by another script).
* fix REPO_LOCAL path to that needed on grass.osgeo.org
* add fetch_unpack_manual_GHA.sh and related crontab entry
* fix script locations
Co-authored-by: Edouard Choinière <27212526+echoix at users.noreply.github.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
