[GRASS-git] [OSGeo/grass] 3ddc3d: GUI: Use for Markdown documentation if available (...
Anna Petrasova noreply at github.com
Thu Feb 13 11:57:59 PST 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 3ddc3d7ba323db8e7374fecf0d2fe6835e8b6006
      https://github.com/OSGeo/grass/commit/3ddc3d7ba323db8e7374fecf0d2fe6835e8b6006
  Author: Anna Petrasova <kratochanna at gmail.com>
  Date:   2025-02-13 (Thu, 13 Feb 2025)
  Changed paths:
    M gui/wxpython/gui_core/ghelp.py
  Log Message:
  GUI: Use for Markdown documentation if available (#5066)
This uses the mkdocs-generated Markdown documentation if available and fallbacks to the original HTML doc if the built doc is not available. It assumes the old HTML doc always exists. It resolves the installed addons only to the extent the original code resolves it, so it should work as long as they come with the legacy HTML doc.
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
