[GRASS-git] [OSGeo/grass-addons] 232a03: style: Fix and enforce unconventional-import-alias...
Edouard Choinière
noreply at github.com
Sun Feb 16 09:38:26 PST 2025
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: 232a035bafa285aa12d1463d202f1b56219ec1e1
https://github.com/OSGeo/grass-addons/commit/232a035bafa285aa12d1463d202f1b56219ec1e1
Author: Edouard Choinière <27212526+echoix at users.noreply.github.com>
Date: 2025-02-16 (Sun, 16 Feb 2025)
Changed paths:
M pyproject.toml
M src/db/db.join/db.join.py
M src/display/d.vect.thematic2/d.vect.thematic2.py
M src/general/g.compare.md5/g.compare.md5.py
M src/general/g.copyall/g.copyall.py
M src/general/g.isis3mt/g.isis3mt.py
M src/general/g.projpicker/g.projpicker.py
M src/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py
M src/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
M src/gui/wxpython/wx.metadata/m.csw.update/m.csw.update.py
M src/gui/wxpython/wx.metadata/mdlib/cswlib.py
M src/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py
M src/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
M src/gui/wxpython/wx.mwprecip/mw3.py
M src/gui/wxpython/wx.mwprecip/mw_util.py
M src/gui/wxpython/wx.rdigit/frame.py
M src/gui/wxpython/wx.rdigit/toolbars.py
M src/gui/wxpython/wx.stream/gui_modules/rstream.py
M src/gui/wxpython/wx.stream/gui_modules/rstream_ImageViewer.py
M src/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
M src/hadoop/hd/hd.db.connect/hd.db.connect.py
M src/hadoop/hd/hd.esri2vector/hd.esri2vector.py
M src/hadoop/hd/hd.hdfs.in.fs/hd.hdfs.in.fs.py
M src/hadoop/hd/hd.hdfs.in.vector/hd.hdfs.in.vector.py
M src/hadoop/hd/hd.hdfs.info/hd.hdfs.info.py
M src/hadoop/hd/hd.hdfs.out.vector/hd.hdfs.out.vector.py
M src/hadoop/hd/hd.hive.csv.table/hd.hive.csv.table.py
M src/hadoop/hd/hd.hive.execute/hd.hive.execute.py
M src/hadoop/hd/hd.hive.info/hd.hive.info.py
M src/hadoop/hd/hd.hive.json.table/hd.hive.json.table.py
M src/hadoop/hd/hd.hive.load/hd.hive.load.py
M src/hadoop/hd/hd.hive.select/hd.hive.select.py
M src/hadoop/hd/hdfsgrass/grass_map.py
M src/hadoop/hd/hdfsgrass/hdfs_grass_lib.py
M src/hadoop/hd/hdfswrapper/settings.py
M src/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.py
M src/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.py
M src/imagery/i.cutlines/i.cutlines.py
M src/imagery/i.cva/i.cva.py
M src/imagery/i.fusion.hpf/i.fusion.hpf.py
M src/imagery/i.gabor/i.gabor.py
M src/imagery/i.image.bathymetry/i.image.bathymetry.py
M src/imagery/i.in.probav/i.in.probav.py
M src/imagery/i.landsat/i.landsat.qa/i.landsat.qa.py
M src/imagery/i.landsat8.swlst/column_water_vapor.py
M src/imagery/i.landsat8.swlst/emissivity.py
M src/imagery/i.landsat8.swlst/helpers.py
M src/imagery/i.landsat8.swlst/i.landsat8.swlst.py
M src/imagery/i.landsat8.swlst/radiance.py
M src/imagery/i.landsat8.swlst/temperature.py
M src/imagery/i.lswt/i.lswt.py
M src/imagery/i.modis/i.modis.download/i.modis.download.py
M src/imagery/i.modis/i.modis.import/i.modis.import.py
M src/imagery/i.modis/libmodis/rmodislib.py
M src/imagery/i.nightlights.intercalibration/i.nightlights.intercalibration.py
M src/imagery/i.ortho.corr/i.ortho.corr.py
M src/imagery/i.sar.speckle/i.sar.speckle.py
M src/imagery/i.segment.stats/i.segment.stats.py
M src/imagery/i.segment.uspo/i.segment.uspo.py
M src/imagery/i.sentinel/i.sentinel.coverage/i.sentinel.coverage.py
M src/imagery/i.sentinel/i.sentinel.parallel.download/i.sentinel.parallel.download.py
M src/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py
M src/imagery/i.signature.copy/i.signature.copy.py
M src/imagery/i.signature.list/i.signature.list.py
M src/imagery/i.signature.remove/i.signature.remove.py
M src/imagery/i.variance/i.variance.py
M src/imagery/i.zero2null/i.zero2null.py
M src/misc/m.cdo.download/m.cdo.download.py
M src/misc/m.crawl.thredds/m.crawl.thredds.py
M src/misc/m.crawl.thredds/testsuite/test_m_crawl_thredds.py
M src/misc/m.printws/m.printws.py
M src/misc/m.prism.download/m.prism.download.py
M src/misc/m.tnm.download/m.tnm.download.py
M src/temporal/t.rast.kappa/t.rast.kappa.py
M src/temporal/t.rast.null/t.rast.null.py
M src/temporal/t.rast.out.xyz/t.rast.out.xyz.py
M src/temporal/t.rast.patch/t.rast.patch.py
M src/temporal/t.rast.what.aggr/t.rast.what.aggr.py
M src/temporal/t.rast.whatcsv/t.rast.whatcsv.py
M utils/std_dataset_display.py
Log Message:
style: Fix and enforce unconventional-import-alias (ICN001) for remaining addons (#1325)
* style: Fix ICN001 for utils
- `grass.script` should be imported as `gs`
Ruff rule: https://docs.astral.sh/ruff/rules/unconventional-import-alias/
* db: Fix unconventional-import-alias (ICN001)
* d.vect.thematic2: Fix unconventional-import-alias (ICN001)
* general: Fix unconventional-import-alias (ICN001)
* gui: Fix unconventional-import-alias (ICN001)
* hadoop: Fix unconventional-import-alias (ICN001)
* imagery: Fix unconventional-import-alias (ICN001)
* i.cva: Fix unconventional-import-alias (ICN001)
* misc: Fix unconventional-import-alias (ICN001)
* temporal: Fix unconventional-import-alias (ICN001)
* style: Enforce `import grass.script as gs` convention
Using ruff rule unconventional-import-alias (ICN001)
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
